Quick question
Discussion in 'Wheels & Tires' started by Motoknuckle, May 10, 2009.
  1. May 10, 2009 at 8:21 AM
    Motoknuckle
    Motoknuckle [OP] Braaaaap!
    Caleb
    Iowa
    02 Prerunner xtracab V6
    Tint, Clear Corners,
    What is the largest tire I can fit on my 2002 pre-runner with stock suspension?
    Thanks!
  2. May 10, 2009 at 8:22 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Should be 265/XX/XX
  3. May 10, 2009 at 8:23 AM
    Motoknuckle
    Caleb
    Iowa
    Will 285's fit?
  4. May 10, 2009 at 8:24 AM
    DanGer
    No, they are too wide, and even with a lift you would have some rubbing issues
  5. May 10, 2009 at 8:28 AM
    Motoknuckle
    Caleb
    Iowa
    I have 275/70/16 on my truck right now with no rubbing...
  6. May 10, 2009 at 8:30 AM
    DanGer
    wow are you sure it doesnt rub when you fully turn? Hopefully chris or will can get on here and tell you from experience on their trucks
  7. May 10, 2009 at 8:33 AM
    Motoknuckle
    Caleb
    Iowa
    I'm positive it doesn't rub.
    I'm thinking about going with 285/75R16...I can deal with a little rubbing.
  8. May 10, 2009 at 8:34 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    youd probably be hard pressed to find a 285 width tire thats short enough to fit a stock suspension
    whats wrong with the current tires?
    and 265/75/16s are generally the largest but that varies with the tire too...each tire is different...and they SHOULD be larger than your current tires...but maybe a half inch skinnier
  9. May 10, 2009 at 8:34 AM
    DanGer
    alright well let some of the first gen guys get on here and answer your question. I was going off what people had been told in the past
  10. May 10, 2009 at 8:37 AM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    i even still had rubbing with one set of 265/75/16s after i had spacers on my truck...
    each tire brand/style is different too...one 265/75/16 may measure out to 32.6" high, and say 10.5" wide...another 265/75 may measure out to 31.8" tall and 10" wide
  11. May 10, 2009 at 8:44 AM
    Motoknuckle
    Caleb
    Iowa
    I have michelin LTX's on my truck right now that are 275/70/16 with no rubbing.
    I'm going to order 285/75/16 terra grapplers and maybe a spacer lift in the front.
    A little rubbing isn't a big deal.:laser:
  12. May 10, 2009 at 8:47 AM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    youre going to have more than a little rubbing with those tires i think
    http://www.tacomaworld.com/forum/tirecalc.php
    i have roughly 3" of lift...run a skinny tire thats close in height to the 285/75/16 and i have rubbing problems
  13. May 10, 2009 at 10:06 AM
    Motoknuckle
    Caleb
    Iowa
    Got any pics of 265/75/16's?
    I can't seem to find any...
  14. May 10, 2009 at 10:21 AM
    DanGer
    Moto I am very sorry, every time I see your posts on the main page I think your user is "Mooseknuckle" haha
  15. May 10, 2009 at 10:28 AM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    several...gimme a few to dig them up
  16. May 10, 2009 at 10:45 AM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    No lift and TRXUS M/Ts
    With a spacer on the front and 265/75/16 Mastercraft Courser MTs
    with SAWs and AAL
    again thought...a lot may depend on WHICH tires you buy...
    i had rubbing with the trxus tires both without and with a spacer lift...i had zero rubbing with the mastercrafts...i have minimal rubbing with SAWs and 255/85/16s but have INSANE rubbing with that size and the spacers
  17. May 10, 2009 at 10:57 AM
    Motoknuckle
    Caleb
    Iowa
    Well I'm going with the Nitto Terra Grapplers.
    That size looks pretty good...those are just a little skinnier right?
  18. May 10, 2009 at 10:58 AM
    Motoknuckle
    Caleb
    Iowa
    I love me some mooseknuckle.:D
  19. May 10, 2009 at 10:59 AM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    just a smidge...
  20. May 10, 2009 at 11:18 AM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    according to the nitto and michelin websites...
    Michelin LTX 275/70/16 is roughly 31.3"x11.1"
    Nitto TG 265/75/16 is 31.54"x10.75"
    285/75/16 is 32.68"x11.34"
    with the 265 it would be .24" taller and .35" skinner
    with 285 it would be 1.38" taller and .24" wider
    its not a LOT of width difference than what you have now...but you also add over an inch of tire height...which could easily change how much, wear, and when the tire rubs
