Quick questions for 5100's
Discussion in '1st Gen. Tacomas (1995-2004)' started by 02 Tacoma TRD, Dec 11, 2010.
  1. Dec 11, 2010 at 6:34 PM
    02 Tacoma TRD
    02 Tacoma TRD [OP] Member
    Oregon
    2002 Tacoma TRD
    Magnaflow exhaust, K&N COI, UWS Toolbox
    Quick questions for my planned lift on my extended cab '02. Here's what I'm doing:
    5100's all around- fronts set at 2.5" with rear Toytec 2" add AAL
    Should I get a 1" CV drop running the 5100's at 2.5"?
    Or would it be better to get an 881 spring and run the front 5100 at 1"? This should definitely need a CV drop right?
  2. Dec 11, 2010 at 8:55 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    With them set at 2.5" it will be a more stiff ride. And since its a 02 and your doing suspension work, might as well replace the springs while your in there for some 881's. And you can do a cv drop kit, but I have seen a 3" lift without it and the cv angles were fine. But you can do it if you would like.
  3. Dec 11, 2010 at 9:13 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    ^^^^ This is good advice.
    I would only add that a diff drop is appropriate as a problem solver. If you have vibs after lifting, check your cv axle boots to make sure the fins on them on not touching. If they are, lowering the diff a little with a kit may be enough to eliminate long term problems.
  4. Dec 11, 2010 at 9:15 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    ^ What he said!:cool:
  5. Dec 11, 2010 at 9:45 PM
    02 Tacoma TRD
    Oregon
    2002 Tacoma TRD
    Alright, the 881 springs lift the front 2" right? So the 5100 on the 15/16" setting will match up good with the 2" AAL?
    A lot of people like Toytec, but $170 for 881 springs sounds pretty steep. Maybe that's a fair price?
  6. Dec 23, 2010 at 8:23 PM
    GOLFMAN845
    GOLFMAN845 Well-Known Member
    Nic
    2002 Black Double Cab 4x4 TRD
    Leather Interior, Hunter Bull Bar with 4" KC Driving Lights, Black Pro Comp 16" Alloy Wheels, Yokohama ATS Tires, OME 881 Coils with Bilstein 5100's set at 1", Rear Dakar Leaf Springs with Bilstein 5125's, Removed Rear Decals on Bed
    Here is what I am running
    OME 881’s | Bilstein 5100’s @ 1” (middle setting)| OME Dakar Leafs | Bilstein 5125’s | Differential Drop Kit
    My coils were like $146
    I am replacing both CV axle's now, they started leaking out grease. I hope it is just because they are woren out at 123,xxx. $66 each to replace new with life time war.
  7. Dec 23, 2010 at 8:35 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    Now: 12 T4R SR5 Then: 99 - 3.4L SR5 4WD
    Wheeler's/Alcan 5-pack leaf springs, Bilstein 5100's front and rear, OME 881's, de-badged, Jungle Fender Flares, Herculined bed, HomerTaco grille, Anzo headlights, clear corners, CVT Mt. Bachelor RTT, custom bed rack & CBI sliders
    NO!! You do not want to pair OME 881's with the Bilstein's if you intend to put the shocks on the highest, 2.5" setting. The 881's are too tall and too stiff to be run in that setup, you will risk damaging the shocks.
    Bilstein's at zero with the 881's will give you a good 2" lift in the front if that is all you are looking for.
    FYI - for 1st gens the setting on the shocks are 0 - 1" - 2.5"
  8. Dec 24, 2010 at 11:23 AM
    02 Tacoma TRD
    Oregon
    2002 Tacoma TRD
    I decided to go with the 881 and 5100 in the front with the 5100 set at 1". I'm using a 2" rear shackle and 5100 for the rear. I am just waiting on the shocks to get here, and the tracking says today, so I should have it all installed in a day or two and have pics up as soon as it's done!
  9. Dec 31, 2010 at 2:38 PM
    02 Tacoma TRD
    Oregon
    2002 Tacoma TRD
