quick rear diff question
Discussion in '4 Cylinder' started by Taco505, Mar 4, 2010.
  1. Mar 4, 2010 at 3:13 PM
    Taco505
    Taco505 [OP] Well-Known Member
    Alex
    New Mexico
    2011 4cyl 4x4 5 speed
    OME 884's/90021, MD Dakar/Nitrocharger.
    hey guys i just have a quick question, i have been searching and i cant find a straight answer.
    just wondering if the 2nd gen, 2wd (non-prerunner), 2.7L tacos have an 8.4" rear diff?
    thanks for the help :D
  2. Mar 4, 2010 at 3:14 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
  3. Mar 4, 2010 at 9:00 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Yes, 5 lugs have a similar diff set up as the T100s (8.4").
    Do you plan on re-gearing?
  4. Mar 4, 2010 at 10:03 PM
    Taco505
    Alex
    New Mexico
    ya im planning on regearing like 4.27's or 4.56's and getting a locker just confused on what size i have haha.
    but thanks for the help guys!
  5. Mar 4, 2010 at 10:23 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
  6. Mar 5, 2010 at 5:57 AM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    What size wheel do you plan on running? Both sound high, the ratio I plan to run with my 31s are 4.10s to get it back into 'factory specs'.
  7. Mar 5, 2010 at 7:24 AM
    Taco505
    Alex
    New Mexico
    well right not i have 255/55-18 alomst a 30 and im looking to regear for performance and add a locker or lsd because i go camping some times and i do some mild off roading its just a pain in the ass when i get stuck haha
    but look at the tire calc for the info i put in: current- 215/70-15
    New- 255/55-18
    http://www.tacomaworld.com/forum/tirecalc.php
    increased power is: 4.27, 4.56
    and if i went back to spec i would do lean toward the high end.
    factory spec: 3.73, 3.91, 4.11
  8. Mar 5, 2010 at 7:35 AM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    Something is wrong with their rpm calculator, or maybe I'm crazy, but...
    I have a 2.7L PreRunner with the 4.11 rear end. I put factory take off 17s on my truck. By the calculator, it says that with 265/65/17s I should be turning 2937 RPMs at 65. However, in my truck I set the cruise at 75 (which is probably 72-73) and I am running around 2700-2800 RPM. Any thoughts how it could be that far off?
  9. Mar 5, 2010 at 7:41 AM
    08pretaco
    az
    i think thats an ideal condition. i think real world is a little less cause you also have many other factors playing
  10. Mar 5, 2010 at 7:42 AM
    Taco505
    Alex
    New Mexico
    that is kinda weird but i actually have no idea myabe your spedo is off?? so the rpms just looks funky when your driving haha
    maybe someone smarter thaqn me can chime in?
  11. Mar 5, 2010 at 7:45 AM
    08pretaco
    az
    the factory speedo is give or take 5% i think. so you might be running actual speed now with the slightly bigger tires, i do with my 265/75/16 actually run the speed my speedo says
  12. Mar 5, 2010 at 7:50 AM
    afd23a
    The Dynamo of Dixie
    :rolleyes:....I've missed out on some things too so I know what you mean :annoyed:
  13. Mar 5, 2010 at 9:23 AM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    Makes since to have more power, the down side is losing MPG. I was thinking of going with 4.56 myself, when I started calling around, more and more people were telling me there is no need for them. So I figured, getting them back into factory spec should be sufficient for my style.
    The only issue I've encounter (like every one else) is driving in deep snow. I have to have a shovel to dig my way out of it. I just want to regear and put in a Powertrax lock right so I can do more difficult trails.
    BTW, where can you get some 4.27 gears for our trucks?
  14. Mar 5, 2010 at 9:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The 5 luggers have a 7.5" rear diff.
  15. Mar 5, 2010 at 9:38 AM
    afd23a
    The Dynamo of Dixie
    I thought that was just the 1st gens that had the "4cyl" diff and that the 2nd gens had the same size ring just different ratios :confused:
  16. Mar 5, 2010 at 9:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    From what I have found, they are a 7.5"
  17. Mar 5, 2010 at 9:40 AM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    From here, I think the 5 lugs have 8.4", same as the prerunners. Here is a link comparing the two with pics.
  18. Mar 5, 2010 at 9:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Interesting......I was under the impresion only the X Runners shared the same size diff.......Thanks for the link!
  19. Mar 5, 2010 at 9:46 AM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    Your welcome. I too found it interesting...
  20. Mar 5, 2010 at 9:50 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Sorry to intrude on your thread but do any tacomas come with lsd
