quick rear susp. question
Discussion in 'Suspension' started by malander, Dec 30, 2010.
  1. Dec 30, 2010 at 7:44 PM
    malander
    malander [OP] Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    I'm trying to figure out everything that I need to save for when I purchase some all-pro leaf springs. So far its just extended brake lines, but my question is will I need greasable shackles for these leaves? or will stock shackles be fine?
  2. Jan 1, 2011 at 8:36 PM
    malander
    max
    01 limited trd 4x4
    anybody?
  3. Jan 1, 2011 at 8:38 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    stock shackles work fine. I have the 3" leaf pack from all pro and i just reused the shackles.
  4. Jan 2, 2011 at 7:58 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Stock shackles will be fine. However...buying the greasable bushings & greasable bolts to put in your leafs (at the eyelets) would be highly beneficial especially down the road....
  5. Jan 2, 2011 at 8:06 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I too bought allpro leafs and I'm using the stock shackles I will mostlikely upgrade to greaseble ones. But for now I'm just going to stick with the stock ones.
  6. Jan 8, 2011 at 6:57 PM
    malander
    max
    01 limited trd 4x4
    Let me know how the expos work out for ya, I'm on the border between those and the standard 3" leaves
  7. Jan 8, 2011 at 6:58 PM
    malander
    max
    01 limited trd 4x4
    Sounds like thats what I will end up doing then. Do you have any idea where I can I get just the greasable bolts and bushings from?
  8. Jan 8, 2011 at 7:50 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    Now: 12 T4R SR5 Then: 99 - 3.4L SR5 4WD
    Wheeler's/Alcan 5-pack leaf springs, Bilstein 5100's front and rear, OME 881's, de-badged, Jungle Fender Flares, Herculined bed, HomerTaco grille, Anzo headlights, clear corners, CVT Mt. Bachelor RTT, custom bed rack & CBI sliders
  9. Jan 9, 2011 at 12:58 PM
    malander
    max
    01 limited trd 4x4
    beefed taco carrier bearing drop is in the mail
  10. Jan 9, 2011 at 12:59 PM
    malander
    max
    01 limited trd 4x4
  11. Jan 9, 2011 at 1:03 PM
    malander
    max
    01 limited trd 4x4
    will new u-bolts be needed? I'm gonna imagine that the new pack will be a bit thicker since it is a progressive. also does anyone have stock measurements of the rear suspension from ground to fender? I'm debating the expo leaves but they do state they will give 1" more lift over the standard 3" leaves.
  12. Jan 9, 2011 at 2:04 PM
    MTgirl
    Weesa
    :thumbsup: No problem. Wheeler's treated me very well when I was purchasing all of my suspension parts.
    U-bolts - yes. You may want to have front hanger bolts on hand too - the old ones can be especially difficult to remove.
    I know the stock height measurements are around here somewhere...if I run across them I will report back!
  13. Jan 9, 2011 at 3:06 PM
    malander
    max
    01 limited trd 4x4
    how many inches longer than stock would you think for the u-bolts? it would be handy to just know how thick the leaf pack is but allpro doesn't list that info.
    Im gonna leave the front hanger bolts up to the shop thats installing all this. I would love to put everything on myself but with my schedule and parents always afraid of me getting underneath a jacked up truck it just doesn't look like its gonna happen. not to mention every time i work on it something goes wrong, don't ask about my 3 day exhaust install....:anonymous:
  14. Feb 2, 2011 at 6:09 AM
    DirtRoadCommute
    DirtRoadCommute Active Member
    NW Florida
    07 Prerunner DC SR5 TRD Off-Road & 96 4X4 SE
    Camburg 4" spindles / Icon extended coilovers / Icon UCAs / All-Pro 3" leaf springs with U-bolt flip / Timbren bumpstops / Fox Shox 2.0 piggybacks / ScanGaugeII / Katskinz leather interior / Cobalt Slim Line toolbox
    Any feedback on the Beefed Taco carrier bearing drop with the AllPro 3" springs? Did you install both at the same time, or did you install the CB drop to correct a drive shaft vibration? If the latter, did it fix the problem?
    Thanks for any information. I'm trying to cure a drive shaft vibration after a spindle lift (front) and AllPro 3" spring lift (rear).
  15. Feb 2, 2011 at 7:37 PM
    malander
    max
    01 limited trd 4x4
    It will be a while before I get everything I'm just rounding up certain parts and the funds for springs. I got the bracket and it's one very beefy piece of metal. It states that it'll drop the carrier bearing 2 3/8 inches if that helps you any.
