Quick RELAY MOD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BSP4x4, Nov 21, 2009.
  1. Nov 21, 2009 at 6:55 PM
    BSP4x4
    BSP4x4 [OP] Guest
    I didn't want the wires coming out of my relay exposed to moisture inside the enigine bay. Could't fine shrink wrap that large.....An old piece of bike innertube works well!
  2. Nov 21, 2009 at 8:18 PM
    JKD
    JKD Well-Known Member
    Another thing to do...get some clear silicone (like Goop! adhesive) and put it in and around the wires where they exit the connector. Be sure to get it up into the connector too (not the contact area, just the place where the wires go in).
    Then, once that goop is hardened, use silicone dielectric grease on the electrical connection side.
    THEN cover it with your inner tube! If that relay experiences water problems, it's probably time to go to the Ark...
  3. Nov 22, 2009 at 5:33 AM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    What does the relay do? Is it a part that is known to cause problems from...
    - humidity?
    - driving through high water?
    - washing the engine?
    - premature component failure from all of the above and for other reasons?
    Thanks!
  4. Nov 22, 2009 at 5:41 AM
    Plain Jane Taco
    Plain Jane Taco I'm not insulting you. I'm describing you.
    Bill
    USA
    2015 SW DCSB TRD Sport PreRunner
    It looks good....but might actually hold in moisture.
  5. Nov 22, 2009 at 5:43 AM
    Brunes
    Brunes abides.
    Rotorhead
    I was just thinking the same thing. You'll still get water in there cause it is not sealed and it'll hold in the folds and stuff.
    I'd go with silicone and dielectric grease if I did anything- and I honestly wouldn't worry about it all that much...but that's just me.
  6. Nov 22, 2009 at 6:38 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    I never really covered my relays at all. So far no problems. Should they be sealed up? They are high up in the engine bay close to the battery
  7. Nov 22, 2009 at 3:19 PM
    BSP4x4
    BSP4x4 [OP] Guest
    No real need to do thi...just me taking an extra step to prolong the life. I'm sure it would be fine without it.
    To answer someone above: a relay acts like a switch allowing power to flow to add on accessories like lights, cb radios etc etc...
  8. Nov 22, 2009 at 6:37 PM
    dktaco
    dktaco Yes MAObama is a joke!
    Josh
    So. Cal (D-town aka Downey)
    05' Pre-Runner SR5 6-spd Modded
    5100's set @ 2.5", Wheeler's AAL, Toyota factory trailer hitch w/ a Reese 3.5" drop ball, Gaylord's Tonneau cover, BLHM w/ 35w 6000k HID's, Lumincs yellow fogs, Sylvania 886 bulbs in taillights for reverse lights, Debadged, Dee-Zee nerf bars, Shorty black antenna, 3M rubberized billet grille & surround, Toyo Open Country AT's 31's, K&N intake, 40 series Flowmaster, Redline Racing Synthetic fluid all the way around, Wet Okole set covers, dash mat, Sirius Starmate 5 hardwired, Cobra radar detector hardwired, paint always taken care of the finest products from Autogeek.net and a Porter Cable dual action polisher.
    Looks weird IMO! +1 on the moisture thing!
  9. Nov 22, 2009 at 6:46 PM
    BSP4x4
    BSP4x4 [OP] Guest
    it's located UNDER the hood:crazy: Who's gonna see it?
  10. Nov 22, 2009 at 6:58 PM
    dktaco
    Josh
    You will! :p Reminds me of a condom going on something it shouldn't. :D
  11. Nov 23, 2009 at 6:31 AM
    BSP4x4
    BSP4x4 [OP] Guest
    hahaha! :)
