quick suspension help on ubolts
Discussion in 'Suspension' started by Hunter500ky, Jun 20, 2011.
  1. Jun 20, 2011 at 6:51 PM
    Hunter500ky
    Hunter500ky [OP] Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    Ok guys need a quick answer rain is coming lol
    I toasted my old u bolts that were longer then the stock ones, forgot to get some today but I have everything almost done.
    My factory ubolts fit BUT there is hardly any thread on it (this is without torquing down to 75lbs).
    Will it work or should I wait till tomorrow and do it in the rain?
    If need be I can wait I am not in a crazy rush to do it, just didnt know if these will work or not.
    Thanks!
  2. Jun 20, 2011 at 6:54 PM
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    Its not going to hurt to try it, unless there is just barely enough thread showing that you strip it out. I'd be carefully of that, but if you can get a few turns on it with your fingers then hit it up with a ratchet you should be alright!
  3. Jun 20, 2011 at 6:55 PM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Yeah no I have them on finger tight.
    I was just making sure I dont need x amount of thread showing ya know?
    Im sure once I start to tighten it down I will obviously get more thread.
    They wont be on about a month Im getting shims and will need longer ubolts
    Just dont want to be driving and my axle wants to leave the truck haha
    so it should be ok?
  4. Jun 20, 2011 at 6:57 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    The rule of thumb I go by is if I can get a full nut worth of thread I run with it.
  5. Jun 20, 2011 at 7:01 PM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Thanks F it Im running with it, If I feel its unsafe Ill just redo it for the 5th time
  6. Jun 20, 2011 at 8:13 PM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Ok guys it's on it looks good. Still a problem, I did this because it looked like my axle was crooked, it still looks that way can someone post a pic from under neath the truck looking at the axle?
