Quick Toytec Coilover with Bilsteins
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nvdeserted, Feb 26, 2009.
  1. Mar 3, 2009 at 8:07 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    x2? I don't think you'll get a "better" ride out of the OME setup... It's just the OME springs ride better with the OME shocks.
    Chris, correct me here, but I do believe you get a little more suspension travel with new UCAs. I don't know how much, but I do believe it's more.
  2. Mar 3, 2009 at 2:30 PM
    S-M-R-T
    S-M-R-T Well-Known Member
    Unless the UCA is hitting the coil preventing full droop your travel should be limited by the bumpstops and/or the shock droop.
  3. Mar 3, 2009 at 9:56 PM
    mtntaco3531
    mtntaco3531 Wandering aimlessly
    Central Idaho
    06 TRD Doublecab 4x4
    Bilstein 5100's with 885's. 2" AAL and Billies.
    I've seen where people are running the OME's with the toytec spacers on top to give a full 3" lift. That way you can still run your 33's, maybe with a little trimming but still opens up your options
  4. Mar 3, 2009 at 10:12 PM
    nvdeserted
    nvdeserted [OP] Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    True. I'm from the "spacers suck" demographic, but a .5" spacer might not be a bad idea. Thanks for the suggestion.
  5. Mar 4, 2009 at 7:07 AM
    Neubs
    Neubs Sold my Tacoma. Goodbye TW.
    Maryland
    06 TRD Offroad DC 4X4
    ToyTec 5100 Bilstein Adjustable Coilovers w/ Eibach Springs | OME Darkar Leaf Springs | 5150 10" Bilstein Rear Shocks| Light Racing UCAs | All Pro U-Bolt Flip Kit | Timbren Rear Bumps | Extended Stainless Steel Rear Brake Lines | ARB CKMA12 On-Board Air Compressor | Method 16" Race Wheels | Goodyear 285/70/16 MTR | 48" Hi-Lift Jack | ToyTec Diff Drop | Warn Hitch Shackle | TRD Cold Air Intake | PIAA Intense White Bulbs | PIAA Silicone Wipers | Toyota Bed Mat |Sockmonkey Graphics | 20% Tint | Sport Hood | Scan Gauge II & Blend Mount | Shrockworks Sliders | ARB Bumper | Warn M8000 Winch | Viking Synthetic Winch line | 12-Volt Guy In-Dash Winch Controller | Viking Delrin Rollers | Daystar Winch Isolator| ARB/IPF 900XS Lights | Weather Tech Liners | Rock Lights | Diff Breather Mod | Extra Bed D-Rings | Misc. LED bulbs throughout
    You are correct, you will get a little more travel with the new UCAs because the upper ball joints will be able to articulate better. Opposed to a stock setup where the ball joint can prematurely limit the suspension from full flex.
