Quick TRD Supercharger questions
Discussion in 'Performance and Tuning' started by Voodoo Rufus, Mar 10, 2012.
  1. Mar 10, 2012 at 12:06 PM
    Voodoo Rufus
    Voodoo Rufus [OP] Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    I noticed on XRU that Werty exploded his engine recently. Also, I read somewhere that the TRD supercharger has a service life of 60k or 100k miles? I know there are ways to prolong the lifespan of the device (changing snout oil regularly), but does the FI system have any business on a vehicle that one plans on keeping or running to 200k miles? I have 44k on my truck right now. What are the options and cost of refurbishing the blower when it's life is up?
    Other questions, performance related:
    1. Does the TRD supercharger require a re-tune if you put a smaller pulley on it for more power?
    2. Can smaller pulleys be put on with little detrimental effects due to a stock exhaust system, or at most a cat-back (CA emissions being the reason)?
    3. Are there any fuel system mods that need to be done for higher boost pulleys?
    4. How easy is it to add a larger capacity radiator for the liquid-air intercooler, and is it really needed for a daily driver vehicle that will not be dragged? The only full power use it should see is while towing (2klb trailer), on ramp acceleration, and additional power for passing.
    A lot of questions, but thanks in advance!
  2. Mar 10, 2012 at 6:32 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    The reason he blew his motor up is because of all the additional mods he did after the s/c. He had a raised rev limiter using the x-1 with a bunch of other addons. To be honest I'll blame the raised rev-limiter for the failure of the engine. It puts stress on parts that aren't made to rev that high constantly for long periods. You shouldn't use his as a basis for engine reliability. I'm not suprised he blew his motor and would of expected it to happen sooner. As with all the other members over on xru that have blown up their motors is because they are pushed to the limit, or screw them up because they don't have a clue when it comes to engine work.
    Adding a s/c shouldn't really take away in the life of the engine. As long as it is maintained regularly there should be no problem. Oil in the s/c should be changed every 100k according to trd, or if you want to change it sooner.
    for your other questions.
    1. Your only option for tuning is with the use of a piggy back system. Map-ecu, ect that urd sells. You can run the urd 2.8" pulley fine on the stock reflash from TRD.
    2. No. Exhaust will help get that exhaust out faster and will make more power because of it.
    3. Yes, you can get larger injectors, but will require a way to tune them. Piggy back computer.
    4. Don't have to change it. TRD did a good job as it comes.
    I installed the s/c on my truck at 14k in 07 have 53k now with no issues. I'm running headers, exhaust, intake, and the APR 2.8" pulley all on the re-flash from TRD.
  3. Mar 10, 2012 at 8:14 PM
    Voodoo Rufus
    Bakersfield, CA
    I know Werty was extensively modded, but it raised questions in my head as to whether a supercharger is truly a long term mod.
    Thanks for answering my questions.
  4. Mar 10, 2012 at 8:32 PM
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    Most likely was the raised rev limiter/e85 tune in my opinion
    The truck had a hot tune and drove amazing. But those stock rods cant handle the stress.
    Truck had 96,000 miles on it. 66,000 boosted and the last 15,000 I had that increased rev limit, which I used maybe....20-30 times.
    Never had any audible knock or power issues. It just let go without any warning. Time to buy some forged rods:D
  5. Mar 10, 2012 at 9:12 PM
    Voodoo Rufus
    Bakersfield, CA
    Sorry to hear about the engine, Werty. I really enjoy your youtube videos and hope you make more in the future.
    So the supercharger doesn't have a service life of 100k, just an oil change interval of that mileage?
  6. Mar 10, 2012 at 9:17 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    The only thing to watch for is if you tow or offroad in hot climate (like arizona or such). My truck gets crazy hot while offroading due to the supercharger. I am thinking of running a pusher fan system as well as the stock fan system.
    I also have the URD 2.8" underdrive pulley installed on mine and it makes a TON of differance. I think it made the truck/supercharger combo what it should have been from the factory.
    Best mod I have done other than the actual supercharger itself.
  7. Mar 11, 2012 at 5:59 AM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    I'd also run URD's Fuel Pump Kit as added insurance. I'm running one now with stock pulley. But plan to go to the 2.85 pulley and hopefully one day get it tuned with the U-CON EMS.
  8. Mar 12, 2012 at 8:57 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  9. Mar 13, 2012 at 12:31 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    What about cleaning the impeller lobes, flushing/cleaning intercooler system and pump, etc....?
  10. Mar 13, 2012 at 9:42 AM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    My plans are to flush my intercooler system when I flush my regular coolant. I figure they have the same service interval considering the fact that they use the same coolant.
    Toyota claims that the S/C does not ever need to be serviced after install. From my browsings around of XRUnderground most of those guys tend to have their snout oil changed around 100k miles of supercharger use. It really depends on how much you beat it up.
    The only other maintenance I could think of would be after a lot of miles >120k or lots of heavy use the internals might need to be rebuilt but I think that would be a case by case choice.
    I've had my S/C on for three weeks now and have loved every minute of it so far!
    Feel free to PM me about a lot of the TRD S/C stuff, I spent a good year gathering as much info and advice as I could before going forward with this as I need this truck to last a VERY long time so maintenance and wear are very important to me.
    DanoDavis likes this.
  11. Mar 20, 2012 at 1:43 PM
    BradleyJ33
    BradleyJ33 Geaux Tigers
    Brad
    Brandon, MS
    2010 TRD Sport 4x4 DCSB S/C'd
    TRD Supercharger with URD 2.825" Pulley, Toytec Ultimate Lift, LR UCAs, BFG All Terrain 275/70R17s on Procomp 7089 17" wheels, BAMF rock sliders, Viper 5902 alarm/remote start with smartstart, Pioneer Avic-Z110BT dvd/navi head unit, 2 Pioneer 7" monitors in headrests, 2 Rockford Fosgate Shallow-mount 10" subs pushed by RF Punch 500.2 amp, RF 5.25 components (front doors) and 5.25 full range (back doors) pushed by RF Power 400.4 amp, sound deadened, Whistler pro remote radar detector, scangauge II, debadged, Sockmonkey decals, blacked headlights with FX-R projectors, DDM Tuning HID fogs, Grillcraft upper and lower MX grill with Hella 500ffs converted to HIDs behind, AFE Stage 2 Cold Air Intake, Walbro 255 Fuel Pump upgrade, Dynomax Super Turbo muffler, Bestop Supertop, Wet Okole seat covers, Weathertech floor liners, Pop & Lock tailgate handle, Lighted 4x4 switch mod, 2 110v AC outlets in cab mod, Always at 400W mod, Maplights on with dome light mod, homelink in headliner mod, foglight
  12. Mar 20, 2012 at 1:51 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    ^^^ Welcome. :thumbsup:
  13. Apr 8, 2013 at 5:56 PM
    Jkohler
    Jkohler HUH?
    Justin
    UT
    02 4DR Taco TDR Supercharged SR5 6in lift
    12" Icon 2.5 coilovers, 6" Drop Bracket, Tuff Country 5" lift knuckles, Icon 4''-8'' Extended Coilovers, Light Racing upper control arms, 7" Alcan leafs, 13" icon 2.0 smooth bodies in the rear. 2.5" exhaust with Magnaflow cats and Thrush muffler. 295x75x16 AT's (34.4") Superchargers Other shit like rear breather mod relocate, gray wire mod, intake elbow removed, led's, toolbox, etc
    Hey all, I dont know if this is the right place to post this but i was reading and have some question it sounds like you guys could help me out with! I have an 02 taco with the black stage 2 supercharger. I have 120k miles and have never done any maintenance or upgrades on the s/c. I've read that i should change the s/c oil (4oz). What else should i do or add to make sure it runs strong for another 80k miles? Any advice or input will be greatly appreciated! Thanks. Justin.
  14. Apr 11, 2015 at 2:15 AM
    CBHoldin
    CBHoldin ispin26
    Dank
    S.W. Colorado
    99 xtra Cab 3.4 Taco/Supercharged
  15. Feb 11, 2016 at 5:39 PM
    Nick'sblue4x4
    Nick'sblue4x4 Well-Known Member
    Nick
    08 speedway blue TRD sport
    Supercharged, completely upgraded sound system, DVD players, camper shell, police scanner
    Old thread but.... You should upgrade your valve body in the transmission before that goes because of the supercharger!
  16. Feb 11, 2016 at 5:48 PM
    Nick'sblue4x4
    Nick
    Yeah for now! My valve body is bad so I'm sending it to itp transmission in new jersey to be fixed/rebuilt, while my truck is down I'm going to go ahead and do maintenance on my s/c. like that speedometer! I have the tacky orange...
  17. Feb 11, 2016 at 5:53 PM
    Nick'sblue4x4
    Nick
    Im at 87k transmission shop quoted 1,797 to put the basic valvebody replacement on... Uh no this is an excuse to beef it up for around 1,000! Why not hahah
  18. Feb 11, 2016 at 5:56 PM
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Link to YouTube videos of this super taco?
  19. Feb 15, 2016 at 5:55 PM
    cdelgado14
    cdelgado14 Well-Known Member
    Alice,Texas
    Supercharged micro machine ;)
    Bilstein 3 inch w/ 5100's
    Are you on the stock fuel pump?
  20. Feb 15, 2016 at 6:38 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    AS Werty(?) on YouTube I believe.
