Quick Wheel Question
Discussion in 'Wheels & Tires' started by TacoTycoon, Jun 12, 2009.
  1. Jun 12, 2009 at 10:56 AM
    TacoTycoon
    TacoTycoon [OP] Well-Known Member
    Justin
    Hayes, VA
    07 TRD Sport 4WD Indigo Ink
    Bilstein 5100 Coilovers, Diff Drop Kit, TSB AAL, 285/70/17 BFG A/T Tires, 17X8 Helo HE835 Wheels, Rear Bilstein 5100s, Dual Flowmaster 50 series, TRD CAI, TRD Front Seat Covers, Rear Suspension TSB, 35% Tint, Redline Hood Struts, MagLite Mod
    There appears to be conflicting opinions on whether or not one should purchase hub centric or non hub centric wheels and I was wondering if anyone knew what would be best for the truck. I am about to drop the coin on some 17X8 4.5in BS and 0mm Offset and I am unsure of what to do about the hubcentricity (not a word but you know what I mean :D)
    Edit: forgot to add I will be running 285/70/17 BFG A/Ts with 3 inch lift.
  2. Jun 12, 2009 at 10:58 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    All I know is if you plan on putting on some 33"s, you will need at least a 4.5" backspacing or a -12mm offset which my 18x9 wheels are.
  3. Jun 12, 2009 at 7:54 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    from what i think hubcentric is the hub on the new wheel matches the thing on the truck where it bolts, non hubcentric will be oversize and you will have problems with vibrations, had that problem on my old car. good luck reading all that, i need a beer.
  4. Jun 12, 2009 at 8:32 PM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    from my research, you do not want hub centric rims, you'll need lug centric rims, so if hubcentric=no, you're good to go
  5. Jun 12, 2009 at 8:35 PM
    TEX357
    TEX357 TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    Which wheels are you planning on ordering?
  6. Jun 12, 2009 at 8:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Now Im finding that the Steel wheels are Lug centric, and the Alloys are Hub Centric???
  7. Jun 12, 2009 at 10:53 PM
    bajamoon
    STEVE
    Whittier
    my procomp's are hubcentric, check out 4wheelparts.com, they show all the wheels that will fit your truck and tell you if they are hubcentric or not.
  8. Jun 13, 2009 at 7:08 AM
    TacoTycoon
    Justin
    Hayes, VA
    Thanks for all the responses guys. I have talked to wheelers and tire rack and they said that the hub centric bore would be too small for our trucks, yet others like bajamoon are having no problems with the hub centric wheels. I plan on getting the pro comp 8190 series
  9. Jun 13, 2009 at 10:46 AM
    TEX357
    TEX357 TX
    05 TACOMA
    I have hub centrics for my pro comps.
  10. Jul 10, 2009 at 3:15 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    i'm about to order some American Racing Mojave Teflon rims for my truck... can't find if they are hub centric or not....??
    anybody know? i know tons of guys on here have them on their trucks...
