Quicksand Paint Tireshine problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dspec, Oct 10, 2018.
  1. Oct 10, 2018 at 7:16 PM
    #41
    usernotfound
    usernotfound Well-Known Member
    Brandon
    CO
    '20 4Runner TRD OR
    So you’re implying that these vehicles do not have a clear coat and use a single stage paint?
  2. Oct 10, 2018 at 7:26 PM
    #42
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Yeah it’s one thing if you did it yourself it’s like well...crap, but paint looking a-okay on the lot and then getting messed up because of some tireshine bullshit is stupid.
    Gator352[QUOTED] likes this.
  3. Oct 10, 2018 at 7:32 PM
    #43
    daveometrod
    daveometrod Well-Known Member
    18 TRD OR 4x4 DCSB Blazing Blue
    My new Taco had that tire shine crap applied by the barrel full. I decided washing the tires and rims would be a good thing. I didn't wash the lower body panels at that time. When I finally washed the truck, I noticed quite a few black dots on the lower body panels. Washing removed the ones above the orange peel painted area, but not on the orange peel painted area itself. But mine is blue and the dots aren't really visible.
  4. Oct 10, 2018 at 7:53 PM
    #44
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Toyota offered too fix the truck,either let them fix it or forget it,they offered you a fix,since you dont want the truck repainted Toyota is off the hook legally.
  5. Oct 11, 2018 at 4:22 AM
    #45
    Gator352
    Gator352 I like Publix cake ...
    Leesburg, Florida
    2018 Super White Tacoma SR5 4x2
    The clear coat is mixed with the base coat so no, it’s not a two stage paint. Only metallic/pearl paint jobs have two stage paint. The CC in say, the super white, makes it shine but doesn’t protect it in any way, shape, or form.
    Freetime likes this.
  6. Oct 11, 2018 at 4:23 AM
    #46
    Gator352
    Leesburg, Florida
    Exactly.
  7. Oct 11, 2018 at 5:41 AM
    #47
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I have a hard time believing tire shine would cause etching in paint. They have go to be spraying some other product on there.
    But thats irrelevent because its their fault regardless.
    I would push for a truck replacement. But you may never be successful with that.
    I would never buy another truck at that dealership again.
    You may want to reach out to a Lemon Law attorney and see if they’d be willing to give you advice on your options and let you know what the legal responsibilities of the dealer are. This may not be a large enough case for them to pursue but you might be able to get some advice at least.
  8. Oct 11, 2018 at 6:03 AM
    #48
    Freetime
    Freetime Well-Known Member
    2016 TRD OR AC 4x4 Quicksand
    Yup. Came here to say this. Quicksand is a single stage mixed paint. There is no clear coat.
  9. Oct 11, 2018 at 6:09 AM
    #49
    PackCon
    Connor
    You really aren’t reading well.
    OP is experiencing etching from what ever product they used to do whatever.
    But deep etching can only be solved be a respray.
    Take the arrogance down a notch. The dealer has already stated the truck HAS to be repainted to fix. Its not a petty issue.
    dspec[OP] likes this.
  10. Oct 11, 2018 at 6:26 AM
    #50
    Gator352
    Leesburg, Florida
    Most tires are treated with an anti mold agent. This agent reacts with tire shine, especially ones that are silicone based. When gooped on or comes in contact with water, it gets flung onto the sides. Silicone based shine is like WD-40. It beads the water up so when it flings off, it makes perfect little dots on your truck that stain. This agent in conjunction with tire shine that causes this issue is known as “tire blooming”. So no, it’s not actually the “shine” by itself.
    The only thing that can be done (before hand) is to pressure wash the tire with a degreaser and scrub brush to remove the agent. Then use shine only after tire is completely clean. This minimizes the effect.
    Like I said earlier, this happened to me. It took 5 days but all the dots faded into oblivion.
    PackCon[QUOTED] likes this.
  11. Oct 11, 2018 at 6:46 AM
    #51
    PackCon
    Connor
    Thanks for the info.
    I’ve used rubber and plastic dressings that can stain the paint and require polishing to remove but nothing bad enough to lead to the etching the OP describes.
    That had to be left on for awhile or some bizzare reaction. Or someone sprayed what they thought was tire shine and was really brake cleaner or some shit that ate the paint.
