Quieter aftermarket exhaust
Discussion in 'Performance and Tuning' started by JAK, Mar 16, 2016.
  1. Mar 16, 2016 at 3:42 PM
    JAK
    JAK [OP] New Member
    Northern Virginia
    2011 TRD Sport 4x4
    Hi All,
    I have a 2011 Tacoma sport doublecab that I bought used. To make a long story short, I was recently told by a mechanic that the exhaust on my truck is essentially a homemade system created by the first owner with a few welded pipes and a cherry bomb to make it loud.
    I want to get a legit aftermarket cat back exhaust system, but I'm sick of the loud constant drone that I have now (trying to talk over the exhaust noise, having to blast music, etc etc). The problem is that all of the cat back systems I have found online are designed to be loud.
    I don't mind a moderate tone, but are there any cat back systems I can get that are on the quieter side??
    Apologies if this is a repeat post; I couldn't find a similar thread.
  2. Mar 17, 2016 at 5:43 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    TRD cat back exhaust
  3. Mar 17, 2016 at 8:42 AM
    keith88lx
    keith88lx Well-Known Member
    Mount Prospect
    15 DCSB TRD Sport 4x4
    I would say TRD cat back or any aftermarket cat back with a resonator (Vibrant Ultra Quiet). Or have stock muffler cut out and an aftermarket muffler welded in and also add a resonator.
    I have a Magnaflow 15315 and added a Vibrant Resonator to it. It's quiet, no drone, and my wife didn't even know I put an exhaust on my Tacoma. Smashing the gas, you can hear it, but it's also nice and quiet on the highway.
  4. Mar 17, 2016 at 11:47 AM
    Vassily28
    +1 for the Vibrant ultra quiet resonator. It tame the sound and reduce the drone a lot. You install it between the flange and the muffler
    Lord Helmet likes this.
  5. Mar 20, 2016 at 1:17 PM
    JAK
    JAK [OP] New Member
    Northern Virginia
    2011 TRD Sport 4x4
    Thanks guys, this is very helpful
  6. Mar 27, 2016 at 11:52 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Another 1 up on the vibrant. Paired with a borla pro xs and I LOVE it. Think trd cat back is Pretty much the same tone as borla too btw. Its almost too quiet for my liking. Probably be just fine without a rez. But you may also be able to get away with just having a muffler of your choice as well as a rez for pretty cheap compared to going full cat back. But hearing you say "homemade with a few welded pipes" makes me think you might be better off doing a new cat back. Depending on how well the previous install was, as far as quality of welds and whatnot, sounds like it may not be the best.
  7. Mar 27, 2016 at 11:58 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    TRD exhaust.
