Quieter Magnuson Supercharger gears.
Discussion in 'Performance and Tuning' started by CD20H, Dec 29, 2018.
  1. Dec 30, 2018 at 11:07 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Sorry to burst your bubble, but those still whine.
    So the whining would still be there regardless if you stick to roots of TVS.
    Whiners.
  2. Dec 30, 2018 at 11:12 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    This seems like a third gen discussion.
  3. Dec 30, 2018 at 11:16 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Get a prius
    12TRDTacoma likes this.
  4. Dec 30, 2018 at 11:30 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    So he can have golf cart whine? He'll complain about that as well.
    blu92in99 likes this.
  5. Dec 30, 2018 at 11:46 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Keep your RPMs down rocket man
  6. Dec 30, 2018 at 11:50 PM
    eon_blue
    Azusa, CA
    I suppose the only real serious answer to this question would be to soundproof your cab.
  7. Dec 30, 2018 at 11:50 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Just tell everyone it has a bad power steering pump. I did that for years with one of my VWs.
    Roostfactor likes this.
  8. Dec 31, 2018 at 2:54 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    The whine was addicting on mine. Only really heard it when i hit the skinny pedal hard though. At cruise it was just tire whine. I miss the noise. Now i have turbo noises :)
    Roostfactor and BassAckwards like this.
  9. Dec 31, 2018 at 2:55 PM
    CD20H
    CD20H [OP] Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    I would burn it to the ground just for it being a Prius. Bad idea.
    1997tacomav6 likes this.
  10. Dec 31, 2018 at 2:57 PM
    CD20H
    Ben
    North Texas
    I have thought about telling people the transmission is on its way out. Theft deterrent.
  11. Jan 6, 2019 at 5:16 PM
    1997tacomav6
    Denver
    The supercharger spins at 15,000 rpms if I remember, so if you want it quieter get a big pulley 3” that will drop the superchargers rpms to 10,000 rpms,
    Never heard someone whining about a supercharger whine
    eon_blue and henryp like this.
  12. Jan 6, 2019 at 6:28 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Straight cut gears always whine no?
    And the gears the spin the rotors are straight cut I thought.
  13. Jan 6, 2019 at 7:06 PM
    ThomasMore66
    I love my whine. I’ve put a series of smaller pulleys on it to make it spin faster and whine more.
  14. Jan 6, 2019 at 7:13 PM
    inwood customs
    Dave
    Silencer port block off plate in the future?
  15. Jan 6, 2019 at 7:25 PM
    #35
    ThomasMore66
    Lol. Maybe open exhaust?
  16. Jan 6, 2019 at 7:27 PM
    #36
    1997tacomav6
    Denver
    :kona:
    Nooo, ear plugs would be better, but seriously it’s not that loud
    https://m.youtube.com/watch?v=ZOp5NaECkJA
  17. Jan 6, 2019 at 8:16 PM
    #37
    inwood customs
    Dave
    Won't effect whine like blocking the silencer ports
  18. Jan 6, 2019 at 8:25 PM
    #38
    ThomasMore66
    Split a bottle of this wine with my wife last night: http://www.orinswift.com/2016Machete Found it to be sublime.
  19. Jan 6, 2019 at 8:30 PM
    #39
    inwood customs
    Dave
    I like a good burgundian Pinot, cab, or sangio.
  20. Jan 6, 2019 at 8:34 PM
    #40
    inwood customs
    Dave
    Fav is windward vineyards 2014 monopole
