Quite possibly the worst soldering job for the overhead compass display fix ever
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wattapunk, Sep 4, 2015.
  1. Sep 8, 2015 at 11:48 AM
    #41
    tgear.shead
    tgear.shead Well-Known Member
    I would *definitely* avoid those for electronics. Their temperature is far too unstable, their tips too big and imprecise, and they blast heat out sideways.
  2. Sep 8, 2015 at 11:52 AM
    #42
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    are you kidding me ? for crawling around and under electrical bits in a vehicle these things rock. you have to know what
    you are doing of course...I can gauge the temp two ways.
    a) with my handy-dandy pocket micro IR thermometer if I was really concerned
    and b) melt speed of the solder at the tip.
    I'd do those smd resistors all day with it. I would not do smd led's or other diodes with it
    *yes they are inaccurate but I've been soldering a long time and reckon it is second nature to me
    to know what I can and cannot do with an unregulated iron. not much I can't do, I have recovered
    numerous computer monitors, motherboards, devices from the trash bin with a butane iron and patience
    when replacing blown components.
  3. Sep 8, 2015 at 12:09 PM
    #43
    tgear.shead
    There is a difference between soldering a 14 ga wire on the side of a transmission and soldering sensitive components to a printed circuit board.
  4. Sep 8, 2015 at 12:23 PM
    #44
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    NO THERE IS NOT you are over-complicating the magic
    I've been doing this for 44 years since I was 4 years old
    rule 1
    don't overheat the component
    rule 2
    melt that shit make it stick
    rule 3
    see rule 1
    SIMPLE
    I have worked in electronic facilities with wave soldering machines as far as the eyes can see and know a wee bit about it. temperature and time. it's a friggin mirror with resistors we don't need IPC J-STD-001 certifications here.
