quoted ~$400 for MT & 4wd fluid service at small Toyota shop, is that excessive? JiffyL wants $450
Discussion in '1st Gen. Tacomas (1995-2004)' started by GQ7227, May 30, 2020.
  1. May 30, 2020 at 11:42 AM
    GQ7227
    GQ7227 [OP] mw survivor
    J A Y
    is the gear oil used in the 1st gen tacos that pricey?
    i am coming up with $55 a gallon and in need of 3 gallons in all (i think)
    is this the good stuff? and what is recommended for use
  2. May 30, 2020 at 11:44 AM
    GQ7227
    J A Y
    unfortunately they would not bundle them all together for me, i did ask for discounted service! $89 each 4wd and $130(ish) for the MT
  3. May 30, 2020 at 11:45 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Well you can't just expect to pay for the fluid itself with a mechanic.
    Mechanics need to make a living; they have overhead costs and still need to support themselves and their family.
    Take the fact that they've got a lot more experience working on cars and trucks than you do, not to mention the means of doing said work.
    If you're inquiring about work for your truck again like you have before, I'd politely ask you to stop wasting other mechanics time unless you're actually going to get it done.
  4. May 30, 2020 at 11:46 AM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    Manual tranny?? Do it yourself. Easy. Diffs are easy as well. $235 is a lot for labor
  5. May 30, 2020 at 11:47 AM
    GQ7227
    J A Y
    i did not realize that fluid was so pricey!
    when i was lubing the 4x4 jeeps 30 years ago this service was $14.95 per gearbox lol
    wilcam47 likes this.
  6. May 30, 2020 at 11:48 AM
    suaveflooder
  7. May 30, 2020 at 11:49 AM
    GQ7227
    J A Y
    :confused:
  8. May 30, 2020 at 11:50 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    And of course, take care of yourself and stop causing yourself so much stress :rofl:
  9. May 30, 2020 at 11:51 AM
    suaveflooder
    Ugh, I feel you, man. Yeah, you may get it a little cheaper, but not much. Honestly I would rather pay more for a trusted shop and forget saving the money. Positive is that it doesn’t need to happen often, so it’s an every couple year “thang.”
    I’m facing the same thing. Always been a manual guy and I hate automatic transmissions when it comes to stuff like this, so paying for the change so it gets done right. Rest (diff) I will do myself
    cruiserguy likes this.
  10. May 30, 2020 at 11:53 AM
    gmr102
    gmr102 Well-Known Member
    Utah County
    Formerly: 2002 Silver Stepside TRD OR Ext Cab V6 Current: 2008 Lexus GX470
    That's about right I think. Manual transmission, transfer case and differential fluids are super simple to change. Oil Weights and capacities are listed in the manual. Don't play that much if you don't have to. It's a lot cheaper if you do it yourself. That way you don't pay the labor for it.
    1997tacomav6 and CD20H like this.
  11. May 30, 2020 at 12:15 PM
    GQ7227
    J A Y
    stress is a killer, definitely!
    1997tacomav6 likes this.
  12. May 30, 2020 at 12:59 PM
    1997tacomav6
    Denver
    It’s super easy to do this fluid changes and you can save plenty of money.
    Goggles
    New crush washers
    Hand held oil pump that attaches to the oil bottles with tube
    Oil catch pan that stores the oil while you drain it.
    Roll of rags.
    GQ7227[QUOTED][OP] likes this.
  13. May 30, 2020 at 1:00 PM
    mud
    mud Djentleman
    SoCal
    2019 TRD OR DCSB LMNOP QRS TUVWXYZ
    I’m watching a YouTube video on how to do it, and will do it for 399.98.
    competition is good for the consumer.
  14. May 30, 2020 at 1:04 PM
    mud
    mud Djentleman
    SoCal
    Reused? I was just going to top it off.
  15. May 30, 2020 at 1:08 PM
    1997tacomav6
    Denver
    You can buy a gallon of RELINE MT90 at mallmart for 70.00 a gallon or a quart for
    22.00
  16. May 30, 2020 at 1:14 PM
    GQ7227
    J A Y
    i have that it takes 4.6 quarts for the MT?
  17. May 30, 2020 at 1:17 PM
    1997tacomav6
    Denver
    5 speed R150 transmission only takes 2.7 quarts I believe
    High Noon likes this.
  18. May 30, 2020 at 1:21 PM
    GQ7227
    J A Y
    i was going by what was on my receipt from having MT done 14 months ago ... 4.6 quarts and 30 minutes labor + supplies, tax + yada yada
  19. May 30, 2020 at 6:50 PM
    1997tacomav6
    Denver
    If it was just the transmission they charged you two extra quarts.
    Did you have the transfer case done too?
  20. May 31, 2020 at 3:06 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Like most any business you have the call on the phone and walk in customer price .
    The regular customer price.
    Our Labor is $40.00 an hour difference between the 2 Parts and supplies are list price .
