Quotes I got today
Discussion in 'Suspension' started by GoDeacsWFU23, Nov 1, 2011.
  1. Nov 1, 2011 at 2:47 PM
    GoDeacsWFU23
    GoDeacsWFU23 [OP] Well-Known Member
    Jonathan
    Clemmons, NC
    2013 Tacoma PreRunner TRD Sport
    I got 2 quotes today on 2 different lifts. The first one was for a 3" ProComp Coil Spring kit for $467.99 and $552.50 to install it. The second is for a 3" OME. It does not come as a kit but was a total of $1102.88 and then $637.50 for install. Are these good prices? Should I stay away from ProComp?
  2. Nov 1, 2011 at 9:49 PM
    skunk
    skunk what did I miss?
    Rudi
    SoCal
    2010 TRD 4x4 (STOLEN)
    YOU WILL BE MISSED Satoshi Grill, FX-R retros, husky liners, bed bolt d-rings, TRD short throw shifter, 2.5 Fox Coil overs, AP UCA's, AP Expo rear leaf with Fox 2.0 shocks, Extended SS brake lines, AP kick-out sliders, 265/75/16 on Konig Countersteers, AllPro Apex front bumper and Zip Ties.
    They are both decent manufacturers but I think the OME might be a more complete package then again I don't know what the kit components are.:notsure:
    And then there is the almighty search....
  3. Nov 1, 2011 at 9:51 PM
    KalamaKid
    KalamaKid Well-Known Member
    Socialist Republic of Oregon
    same shit as everyone else
    What are all the items that come with the OME lift? If it comes with the Dakar rear leaf packs thats a good price, if your not getting the Dakar leaf packs then your can get the OME kit much cheaper.
  4. Nov 1, 2011 at 9:52 PM
    ttran
    ttran Expert Mallcrawler
    Tim
    Charlotte, NC
    06 DCLB Prerunner Sport
    TRD Sport Prerunner
    I would install it yourself OP to save money... They're not that hard to install and I'm sure local members would assist you.
  5. Nov 1, 2011 at 9:54 PM
    yotamikez
    yotamikez Street glide or die
    Valrico
    04 civic & 08 Street glide
    OME does come as a kit... and those install prices are crazy. I suggest you look around.
  6. Nov 1, 2011 at 9:56 PM
    KalamaKid
    Shop rate is normally about 90-130$ and HR. OME kit is going to take at least three-four hours for one tech to install plus an alignment for another $70-80. Sounds like the install prices are about right.
  7. Nov 1, 2011 at 9:57 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Install rate isn't that crazy
  8. Nov 1, 2011 at 10:00 PM
    yotamikez
    Valrico
    Yeah now that I think about it your both right. Never had anyone I know have a shop isntall their lift, always been a group thing so I didn't think It would be that high.
  9. Nov 1, 2011 at 10:02 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    yeahh any price looks high as hell when you can either install yourself or have some buddies help you for FREE ahah.
  10. Nov 1, 2011 at 10:07 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I can't really recommend the ProComp unless you're putting on a really heavy bumper and winch combo - it's got crazy stiff springs.
    If you want to save a buck, you can get Add-A-Leaf instead of Leaf pack in the rear.
    If you want to save another buck, you can get bilstein springs and eibach springs with an add-a-leaf in the back from ToyTec for around 600 for parts.
    http://toyteclifts.com/index.php?pa...tegory_id=113&option=com_virtuemart&Itemid=72
  11. Nov 2, 2011 at 3:55 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    Thanks for all the input everyone!! But, after finally finding a 4-5" suspension that I have been looking for I am going to go with this one. Even though the price is quite a bit higher, this is what I want and am willing to pay the extra money to get exactly what I want.
    RCD 4"-5" 05+ Tacoma Lift: 1799.00[​IMG]
    [​IMG]Heavy Duty Front Sway Bar Drop Down Brackets[​IMG]Custom Matched Bilstein 5100 Series Monotube Gas Pressure Rear Shocks
    CNC Machined Replacement Cast Iron Steering Knuckles for Precise Steering Geometry
    [​IMG]Heavy Duty Two Piece Lower Sub-Frame Assembly and Polished Stainless Steel "Twin -Link" Anti-Compression Struts Insure Structural Strength and Durability [​IMG]Heavy Duty differential Skid Plate that Intergrates the Cross Members and adds additional protection [​IMG]RCD "Gator Black" Polyurethane Powder Coat Finish for Lasting Good Looks[​IMG]Grade 8 Hardware for Reliability[​IMG]Front & Rear Brake Line Brackets
  12. Nov 2, 2011 at 3:57 PM
    KalamaKid
  13. Nov 2, 2011 at 4:04 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Why not go with spindles since you're a prerunner?
  14. Nov 2, 2011 at 4:13 PM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
  15. Nov 2, 2011 at 4:18 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    I have talked to a few people and they said they had trouble being able to align the truck after spindles were installed.
  16. Nov 2, 2011 at 6:01 PM
    OZ-T
    Peter North
    British Columbia
    Do you have to cut the frame on the prerunners for the RCD lift ?
  17. Nov 2, 2011 at 6:07 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    no idea
  18. Nov 2, 2011 at 6:48 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    Forget the RCD.....after reading a post that was just put up about suspension and me being able to finally understand it (i think) I have changed everything to the following. It is all OME....let me know if this looks like a good set-up.
    Shopping Cart
    1 x OME N182 Rear Shocks (05 & UP Tacoma)
    $179.99
    1 x Shocks (05 & UP Tacoma/FJ/03 & Up 4Run)
    $314.99
    2 x OME Rear leaf spring 2005-2010 Tacoma**PRICED EACH**
    $399.98
    1 x OME Trim Packer
    $8.99
    1 x Front OME Lift Coils
    $169.99
    Select coil: 885 Med coils
    Options: No top plate spacers 6 Products
    $1 020.24
  19. Nov 2, 2011 at 6:50 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    Its a good thing I can make everyday life decisions better than this.......
