R&D New Tacoma specific front bump stops
Discussion in '1st Gen. Tacomas (1995-2004)' started by Plastics Guy, Apr 24, 2018.
  1. May 9, 2018 at 10:25 PM
    #41
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    X2
    erice and eccracer104[QUOTED] like this.
  2. May 9, 2018 at 10:35 PM
    #42
    Jebediah
    Jebediah Well-Known Member
    Eli
    Colorado
    1998 White TRD.. 'Augustus'
    I'm interested
  3. May 10, 2018 at 3:16 AM
    #43
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
  4. May 10, 2018 at 6:19 AM
    #44
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I'm interested as well
    Prayn4surf likes this.
  5. May 10, 2018 at 7:18 AM
    #45
    cynicalrider
    cynicalrider #NFG
    Jersey
    :popcorn: How does it look compressed?
    erice and Prayn4surf like this.
  6. May 10, 2018 at 7:37 AM
    #46
    Prayn4surf
    Socal
    X2 again lol
    erice likes this.
  7. May 10, 2018 at 7:56 AM
    #47
    Plastics Guy
    Plastics Guy [OP] DuroBumps
    DuroBumps
    Arizona
    02 4Runner
    Plasti-dip & exhaust tip
    erice likes this.
  8. May 10, 2018 at 9:58 AM
    #48
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    If i remember correctly,
    The 2010+ 4runner / FJ / 3rd gen Tacoma all share the same LCA.
    the 2nd gen Tacoma either has a different size bushing sleeve and /or spacing between bushings front to rear is different.
    Plastics Guy[OP] likes this.
  9. May 10, 2018 at 10:13 AM
    #49
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Did you build your own mold? Are you mixing the material and casting them yourself?
    erice and lukester78 like this.
  10. May 10, 2018 at 11:04 AM
    #50
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    interested
  11. May 10, 2018 at 11:09 AM
    #51
    cynicalrider
    cynicalrider #NFG
    Jersey
    Ah so the rear bump will be the actual bump "stop" and the fronts will act as the slowing to full bump part?
    I'm assuming these things are being 3-D printed based on the looks, but that's just guess.
  12. May 10, 2018 at 3:50 PM
    #52
    Plastics Guy
    DuroBumps
    Arizona
    02 4Runner
    You got it, I do it all.
    lukester78 and erice like this.
  13. May 10, 2018 at 3:51 PM
    #53
    Plastics Guy
    DuroBumps
    Arizona
    02 4Runner
    They are originally 3D printed with a ton of post print finishing.
  14. May 10, 2018 at 3:52 PM
    #54
    lukester78
    lukester78 Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
    What's your mold made from? I was interested in trying some slip casting a while back, never got around to it.
  15. May 10, 2018 at 3:54 PM
    #55
    Plastics Guy
    DuroBumps
    Arizona
    02 4Runner
    I'm a custom mold maker so if you need any molds, I'm your guy.
    My molds for the front bump stop are made of silicone and urethane plastic.
    erice likes this.
  16. May 10, 2018 at 3:57 PM
    #56
    erice
    erice Well-Known Member
    Eric
    San Diego
    @Plastics Guy , What kind of timing are we looking at for an R&D product and possibly a final production run?
    From what it looks like its almost there.
  17. May 10, 2018 at 3:58 PM
    #57
    Digiratus
    Roaming the PNW
    The RedHead
    Suspected as much. In a previous career, I use to do a lot of production molding for a variety of polyurethane products. Lots and lots of wheels.
  18. May 10, 2018 at 4:10 PM
    #58
    Plastics Guy
    DuroBumps
    Arizona
    02 4Runner
    I am very close. The design in the picture I attached ended up being a FAIL. So I redesigned it a bit and am heading out next week for testing.
    If all goes as planned I intend on shipping out a few beta sets to get further feedback from other members.
    Then mass production!!!...
    BYJOSHCOOK and erice[QUOTED] like this.
  19. May 10, 2018 at 5:25 PM
    #59
    BajaSurfRig
    BajaSurfRig Well-Known Member
    2000 Tacoma 4wd Trd 5sp Callen Camper
    The ones I posted in my photo are wheeler's super bumps for a second gen trimmed to fit a first gen. Retrospectively I wish that I had trimmed them at a diagonal, not just flat across the top...
  20. May 10, 2018 at 5:40 PM
    #60
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Rough cost?
    Jebediah likes this.
