R&D New Tacoma specific front bump stops
Discussion in '1st Gen. Tacomas (1995-2004)' started by Plastics Guy, Apr 24, 2018.
  1. Jul 6, 2018 at 1:30 PM
    #121
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    I hear that’s the best stuff to pan for gold with.
  2. Jul 6, 2018 at 2:08 PM
    #122
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    They look good. My only thought/concern is that if the open end is pointing up, how hard would it be to get say a rock or mud/dirt in it? And if it was to be filled by a hard (er) substance, what would happen to the bump stop under load? Would it split? Would it still function as desired?
  3. Jul 6, 2018 at 2:13 PM
    #123
    mateo_roberto
    Mateo
    San Diego, CA
    Stock
    It’d be really easy to plug it if that’s what your main concern is. Or OP could make a neat little 3D printed plug and sell it to you for $19.99. You’re supposed to wash your truck from time to time as well.
    I can’t imagine a rock getting Michael Jordan’d inside the bumpstop while running really hard, and then also not being able to bounce right back out. Superbumps and Timbrens never have these issues and they’re both designed with a pocket.
    OneWheelPeel likes this.
  4. Jul 6, 2018 at 2:21 PM
    #124
    COMAtized99
    North Carolina
    99 DCLB v8
    Ive never even thought about swapping bump stops until this thread popped up. So I have no clue who makes replacement parts for them. If you can't imagine a cup shaped space facing up getting filled with mud and dirt or passably a rock, you have never wheeled on the east coast. Mud is unavoidable on the trails. In my mind, there is a decent chance that it could happen, and if it did, what effects would it have on the bump stop?
  5. Jul 6, 2018 at 2:28 PM
    #125
    mateo_roberto
    Mateo
    San Diego, CA
    Stock
    Are you saying the west coast doesn’t have gravel or rocks?
    Like every other suspension component on your truck, you’re supposed to visually inspect prior to going offroad. Once again, anything that can easily bounce in should and will bounce out given the time. Heaven forbid there are a few rocks in the bumpstop, and your truck completely bottoms out with rocks inside. You would just end up with more smaller rocks in the bumpstop.
    I ran superbumps on my last truck, and yes the pocket will collect dirt. Wash it out, and dry it so the water doesn’t sit in it. Or if all of that sounds too intense, just stuff some crumpled up duct tape in there and call it a day.
  6. Jul 6, 2018 at 2:36 PM
    #126
    COMAtized99
    North Carolina
    99 DCLB v8
    Do you have stock in these bump stops or something? I'm literally just asking the op a question. The title of this thread begins with R&D.. he asked what "we" thought.
    When my group gets together and wheels, we normally go for a long weekend. 3-4 days. In that time none of use wash our trucks in that tome. Some weekends it rains the whole time or has rained the week before and everything is a sloppy mess. When I say gravel, im not talk about the kind on your driveway. I'm talking about the small stuff thats in.mud. so yes, something getting trapped in there is a possibility. It might be a non issue. IDK, that's why I asked.
  7. Jul 6, 2018 at 2:42 PM
    #127
    mateo_roberto
    Mateo
    San Diego, CA
    Stock
    Look man I’m sorry if it comes off like i’m attacking you, not my intention at all. I’ve been trying to provide answers to your question, which I’m certain I did.
    Everyone on here has their own 2 cents, and here’s mine. The best way to test these things is to install them and run them in the real world. Your concerns are valid, although I don’t believe it’s an issue. The longer OP has to wait responding to these things and doing redesigns, the longer it takes to get them in our hands. If you fill yours with rocks and they split apart, i’m sure this entire thread would love to see it and we could all learn something, implementing a change in V3
  8. Jul 6, 2018 at 2:46 PM
    #128
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Man, so on the fence here. Maybe when you do the rears, I'll order all of them. I really just do slow crawling from time to time but these will be good to have.
  9. Jul 6, 2018 at 3:33 PM
    #129
    Plastics Guy
    Plastics Guy [OP] DuroBumps
    DuroBumps
    Arizona
    02 4Runner
    Plasti-dip & exhaust tip
    This thread originally started off just as a simple "what do you think" after a few months and a ton of feedback, design changes, prototypes to production models its turned more into a frenzy of "I want a pair". At this point I am done with the R&D and offering the V2 front bump stop for sale. This bump stop may not be perfect for everyone's specific needs, but it is for the majority, Especially now I have the V2.
    I read that you never thought of bump stops before reading this thread. The reason these were made in the first place is because I was in the market looking for bump stops. What I found was all the aftermarket guys are trying to make there bump stop fit as many different vehicles as possible to sell to a wider audience to make more sales. It makes perfect business sense...
    due to the universal fit whats available aftermarket does not fit properly (to big, to tall) and all of the aftermarket bump stops interfere with the shocks dampening ability because the bump stop is in constant contact with the frame/strike pad. .Why do we spend big $$$ shocks just to have a piece of rubber or foam interfere with the dampening of the shocks. My bump stop was designed to be as short as possible as to not interfere with the shocks dampening. They were also designed prevent the hard contact that we are all familiar with when hitting a OEM bump stop.
    We all build are trucks to fit our specific needs and this bump stop was made to fit the bill for me. I have not had any issues myself with debris filling the cavity. The hole is only about 1-1/4" deep or so.
    I don't believe debris would become a problem, but there are to many variables to really say definitely. When you talk about gravel and mud, I would think it would simply squish out.
  10. Jul 6, 2018 at 3:41 PM
    #130
    Plastics Guy
    DuroBumps
    Arizona
    02 4Runner
    Hey JJ04TACO, I think you will be just fine without them for now. Once your ready, I'll still be around. When you get to a point on the trail of hitting your OEM bumps a few times really hard, that's when I would consider spending the money. I ran trails for years with my OEM's banging. Its loud and it hurts... so I started looking into solutions and didn't find any aftermarket options that i Liked so I made my own. I'm in the plastics and rubber industry, so building bump stops is kinda like a carpenter building a dog house...
  11. Jul 7, 2018 at 11:49 PM
    #131
    UnderFire
    UnderFire Well-Known Member
  12. Jul 8, 2018 at 7:21 AM
    #132
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
  13. Jul 9, 2018 at 6:30 AM
    #133
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    FWIW I've got timbrens on the rear and they tend to get mud inside the cup. Doesn't affect how they run, I don't really notice until I'm washing the truck and mud comes flinging out. I've also had water freeze a little in there too. So far after 2 years I have no issue
  14. Jul 17, 2018 at 12:59 PM
    #134
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Stoked to see some of the installed pics when they are finally sent out
  15. Jul 18, 2018 at 4:02 PM
    #135
    cynicalrider
    cynicalrider #NFG
    Jersey
    So according to the photo's they should be installed as the rear bump vs the front bump on the LCA? Got mine today! In your testers experience, has this been the best way to run them?
    Digiratus likes this.
  16. Jul 18, 2018 at 4:28 PM
    #136
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Actually I was wondering this myself...I assumed I should be putting them on the front (closest to the grill) but the pics on page one show them on the rear of the LCA. I've seen other guys retro-fit Wheeler's bumpstops to go on the front. Is it just personal preference or is it better to put them on the rear?
  17. Jul 18, 2018 at 4:32 PM
    #137
    OneWheelPeel
    Phoenix, AZ
    Maybe thats where the 4 runner bump stop is?
  18. Jul 18, 2018 at 4:34 PM
    #138
    eon_blue
    Azusa, CA
    Front ends between the 2 are virtually the same (3rd gen T4Rs and 1st gen Tacomas), not sure if it would make a difference but maybe :notsure:
  19. Jul 18, 2018 at 5:55 PM
    #139
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  20. Jul 18, 2018 at 6:26 PM
    #140
    Digiratus
    Roaming the PNW
    The RedHead
    It looks like the stock front pad is larger than the rear. It looks like the top surface is broader and maybe a smidge taller. I wonder if it is better to replace the smaller rear one because of this size difference.
    For reference, this a photo of Frankenstein's original passenger side UCA, borrowed from @Blackdawg
    [​IMG]IgorsBumps-2.jpg by Monte Nickles Photos, on Flickr
    From left to right: OEM Rear, OEM Front, ES Foam and Wheelers SuperBumps (for 2nd Gen)
    [​IMG]IgorsBumps-5.jpg by Monte Nickles Photos, on Flickr
    SmartShox671 likes this.
