[ R E C H E L O N ] 2005-2011 TACOMA RETROFITTED HEADLIGHTS [ AESTHETICS ]
Discussion in 'Automotive Group Buys' started by RAD, Oct 8, 2016.
  1. Oct 8, 2016 at 6:37 PM
    RAD
    RAD [OP] Well-Known Member Vendor
    Rad
    LAX & LOGAN
    R E C H E L O N|AESTHETICS
    Our Passion is to Handcraft Custom Detailed Headlights
    Driven to Balance Aesthetics w/Performance
    GROUP BUY [ STARTS OCTOBER 8TH 2016 | ENDS NOVEMBER 1st 2016 ]
    A/M TOYOTA 2005-2011 RETROFITTED HEADLIGHTS
    [ STAGE I $750 BASE PRICE SHIPPED ]
    - Brand new aftermarket headlights
    - Morimoto Mini H1 7.0 projectors
    - Shroud Design of your Choice / Check The Retrofit Source's website @ (http://www.theretrofitsource.com/components/shrouds.html )
    - Blacked Out Paint Work ( BEZEL / BOWL / SHROUD / DTRL BLINKERS )
    - You can request to leave certain parts of the headlight chrome
    - Smoke Amber Reflector ( Can Leave Stock Amber )
    - Brand New 35W Morimoto ballasts
    - Brand New XB35 Morimoto Bulbs (We Recommend 4500k or 5500k)
    - Brand New Morimoto H4 Wiring Harness
    [ STAGE II $795 BASE PRICE SHIPPED ]
    - Brand New FX-R 3" Projectors
    [ Additional Option ]
    - Clear Blinker/DTRL Lens that replaces the slightly yellowed version. Clear lens by DKMoulds + $50
    OEM TOYOTA 2005-2011 RETROFITTED HEADLIGHTS
    [ OEM STAGE I $995 BASE PRICE SHIPPED ]
    - Brand new OEM headlights (with glass DTRL/turn signal)
    - OEM TRD PRO BLACK SMOKE / CHROME FACTORY COLOR SCHEME
    or
    [ OEM STAGE II $1050 BASE PRICE SHIPPED ]
    or
    ADDITIONAL OPTIONS FOR ALL STAGES
    - Passive Demon Eye / Subtle color accent inside the projector lens / Does not light up ( Color of your choice ) +$50
    - LED Demon Eye / Lights up inside the projector lens. (Color of your choice - Red, Blue, Green, Amber, or Purple) +$80
    - Halos (White & Amber Switchback / Front or Rear mounted) +$100 For One Set / +$180 For Both Front & Rear
    - RGB Color Changing Halos +$150 / +$270 For Both Front & Rear
    - RGB Color Changing LED Demon Eye +$150 ( Recommend to Wire them to a Switch/Button )
    +$270
    For Both RGB HALO & RGB LED DEMON EYE
    - Clear / Light Clear Smoke / Dark Clear Smoke Replacement Reflectors
    Replaces Stock Amber +$45
    - Black Chrome or Chrome Parking Light Corner +$20
    - Custom Color Matched Paint work / Our Professional Painter uses the best paint & clear product by GLASURIT. ( Pricing Varies )
    - Custom Art/Design Etching in Projector Lens +$45
    - OEM Upgraded Bulbs are Available to compliment your Choice of Projector (Pricing Varies)
    - 50W Ballasts instead of 35W +$10
    ChadsPride and ChemDawg like this.
  2. Oct 8, 2016 at 6:39 PM
    RAD
    Rad
    LAX & LOGAN
    HAVE YOUR OWN OEM HEADLIGHTS?
    WE CAN BUILD OFF OF THOSE AS WELL
    Contact us directly as we can work out the details
    Follow us on Instagram
    RECHELON.AESTHETICS
    Questions/Inquries or Concerns
    [email][email]rechelon.aesthetics@gmail.com[/email][/email]
    FAQ
    Q. Is there a warranty?
    A. Yes. We offer a six month warranty on workmanship. TRS components follow the TRS warranty period. For example, 5Five Ballasts carry a 24 month warranty. 3Five ballasts carry a 60 month warranty. Etc... No hassle warranty. Shipping cost will be taken care of by TRS for U.S. transactions. For owners outside the U.S., you will be responsible for the shipping cost per TRS.
    The cost of shipping the headlight(s) to to me is the original owner's responsibility. I will be responsible for the cost of returning the warrantied headlight(s) to the original owner within the U.S. Sorry, if you are outside the U.S., you pay shipping both ways. This warranty is NOT transferrable. Any modifications and/or tampering of headlights will void the warranty.
    Q. How hard is it to install the headlights and wire harness once I receive them?
    A. If you have a slight bit of mechanical skills, then the installation will not be difficult. The wire harness is plug 'n play, no splicing of the OEM harness is required (unless your lights are equipped with LED Angel Eyes). The new, retrofitted headlight bolts up the same way your old one was removed. Wire harness instructions are included with your shipped headlights as well as online.
    http://www.theretrofitsource.com/pdf/trs_tech/Bi-Xenon MotoControl Relay Harness.pdf
    The OEM headlight aiming mechanism remains fully functional. After your retrofitted headlights are installed, some fine tuning will be required utilizing the OEM adjusters. Fine tuning is defined as matching both the left and right cut-off so that they are level with each other. As a rule of thumb, I recommend aligning the height of the cut-off to be horizontal with the upper trunk line of the average sedan.
    Q. Where can I learn more about retrofitting, projectors and HID bulbs?
    A. The Retrofit Source (TRS) has a tremendous amount of online material to enhance your retrofitting knowledge.
    http://www.theretrofitsource.com/trs_tech.php
    Q. What's the difference between the bulb colors?
    A. Kelvin Ratings: 3000K - Has a golden yellow output perfect for use in fog lights. The yellow light penetrates through snow, rain, and fog more effectively than white or blue light. 4500K - Has a slightly off-white output similar to that of sunlight. Most cars that come equipped with HID headlights from the factory use 4300K bulbs. If you want the most usable light, 4500K is the Kelvin rating for you. 5500K - A pure white output, no tinge of yellow, and no tinge of blue. 6500K+ As you move into the higher kelvin ratings, your light output will appear more bluish-purple in hue, but the bulbs won't be physically as bright. I do not offer 6500k bulbs. As HID bulbs age, they go through what is known as "color-shift". When the bulbs are brand new, the output is whitish-yellow and as physically bright as it will ever be. As the bulbs age with use, their output turns more pure white/bluish and also starts to dim a bit. That's why cars with factory 4500K bulbs that are 5+ years old look like they're running 5500K or higher bulbs.
    ChadsPride likes this.
  3. Oct 8, 2016 at 7:09 PM
    RAD
    Rad
    LAX & LOGAN
    [ 2015 DEFCONBRIX x RECH|CONBRIX SEMA BUILD ]
    THE STEALTH FSU
    [ UNIFORM INSPIRED BUILD ]
    Sect0r - brand new OEM headlights, G37R shroud with white halo in rear, flat black paint, smoked reflector
    temper - Brand new OEM headlights, G37R shroud w/ RGB halo, flat black paint, smoked reflector
    Idaholandho - brand new OEM headlights, anodized blue demon eye, bullet shroud, flat black paint, smoked reflector
    w/ flash on
    Dave P - Brand new OEM headlights, Panamera shroud with front and rear mounted amber halo, flat black paint, smoked reflector
    almoss - brand new OEM headlights, DTRL and Apollo 3.0 shroud left chrome, smoked reflector
    iHacker - Brand new OEM TRD Pro headlights (black chrome finish), Apollo shroud, everything left alone for an OEM look
    Flat black bezel, Shroud, Bowl, DTRL, and corner bowls all left chrome, amber halo, Apollo shroud
    TACOMAA6 - Brand new OEM headlights, Apollo 3.0 with white front mounted halo, red passive demon eye, smoked reflector, flat black paint
    Toyota Technical - Brand new OEM headlights, Panamera shroud with front and rear mounted amber halo, flat black paint, smoked reflector
    THE BUELL
    BLACK BEZEL | MAGNETIC GREY METALLIC BOWL & SHROUD | GUNMETAL PASSIVE DEMON EYE | CLEAR REFLECTOR |
    OEM SMOKE BEZEL | MAGNETIC GREY METALLIC BOWL & SHROUD | GUNMETAL PASSIVE DEMON EYE | CLEAR SMOKE REFLECTOR
  4. Oct 8, 2016 at 7:43 PM
    RAD
    Rad
    LAX & LOGAN
  5. Oct 9, 2016 at 5:03 PM
    RAD
    Rad
    LAX & LOGAN
    Thanks for the emails & interest
    Some questions/concerns that were asked
    Unfortunately, we don't have any matching fogs for the 2005-2011 Model
    There isn't an option for the TRD Smoke bezel on the aftermarket headlight options. You'll have to purchase the OEM Toyota HL.
    Kind regards,
    R A D
  6. Oct 10, 2016 at 7:01 AM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Is this a group buy or recurring sale?
  7. Oct 10, 2016 at 7:03 AM
    RECHELON
    RECHELON RETROFIT HEADLIGHTS
    RECHELON AESTHETICS
    SoCal to Portland
    DCX2
    This is a limited time groupbuy.
  8. Oct 10, 2016 at 7:13 AM
    RECHELON
    RECHELON AESTHETICS
    SoCal to Portland
    DCX2
    LED Halo foglights will be available using Morimoto foglights.
  9. Oct 10, 2016 at 9:07 AM
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    Subbed. Man I would love a set of these.
  10. Oct 10, 2016 at 11:04 AM
    RAD
    Rad
    LAX & LOGAN
    The Matching LED FOG / HALOS will be added to the GB for the 2005-2011 Tacomas
  11. Oct 10, 2016 at 11:39 AM
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    You show a lot of 12+ lights, you going to offer them at a different time?
  12. Oct 10, 2016 at 11:41 AM
    RECHELON
    RECHELON AESTHETICS
    SoCal to Portland
    DCX2
    WhiteNemesis[QUOTED] likes this.
  13. Oct 10, 2016 at 2:35 PM
    DollarTacos
    DollarTacos Well-Known Member
    LongIsland, NY
    11 Taco
    RCD Lift, fog light anytimemod, N-Fab rock sliderz, rockstars, putco LED dome light kit, blackuot front lip, 30" Riged LED, Rigid SR-Q2 aux backup lights
    What is pictured in the first post, last two pictures. Looks like side reflector replaced with carbon fiber cover or is that reflective something?
  14. Oct 10, 2016 at 4:57 PM
    eppy
    eppy Well-Known Member
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Homer M3 thin lip Satoshi, BAMF Light Bar, BAMF Batwing Tie Downs, Coupe Custom Battery Hold Down, Mattgecko Bed light kit, nj636 hub/wheel bearing set-up,Shorty Antenna, JL Audio & Boston set-up, 4x4 switch light MOD, Icon 2.5 coil overs and rear shocks, All Pro flip kit, Wheelers AAL, OcTaco SS brake lines, Light Racing UCA's and custom 6 speed Ellis Precision Shift knob. Coupe modified short shifter, AISN clutch pack, URD TOB kit, and Sachs flywheel. Mobtown's rocking tailgate skin!
    Hey guys, I'm trying gain a little insight on the group buy because I have 2005 that I'm looking to upgrade the headlights. If I'm reading correct is fog lights being added to the group buy? And I also have OEM's that I can send to modified. So let me know what's up???
  15. Oct 10, 2016 at 11:20 PM
    RAD
    Rad
    LAX & LOGAN
    The 2005 HL are up for group buy and we also added matching LED Fog Light with Halos as another option for Group Buy. Compliments one another in perfect Harmony.
  16. Oct 11, 2016 at 1:04 AM
    eppy
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Thanks, I appreciate it. Please PM me the total price for the fog & headlight group buy.
    Thnx,
    Eppy
  17. Oct 11, 2016 at 7:10 AM
    RECHELON
    RECHELON AESTHETICS
    SoCal to Portland
    DCX2
    PM'ed
  18. Oct 11, 2016 at 10:18 AM
    RAD
    Rad
    LAX & LOGAN
    I believe it's just a reflection from the smoke reflector. It's playing off the design of the actual reflector.
    DollarTacos[QUOTED] likes this.
  19. Oct 12, 2016 at 10:17 AM
    RAD
    Rad
    LAX & LOGAN
  20. Oct 13, 2016 at 7:17 AM
    RECHELON
    RECHELON AESTHETICS
    SoCal to Portland
    DCX2
