[ R E C H E L O N ] 2012-2015 TACOMA RETROFITTED HEADLIGHTS [ AESTHETICS ]
Discussion in 'Automotive Group Buys' started by RAD, Oct 8, 2016.
  1. Oct 8, 2016 at 6:56 PM
    RAD
    RAD [OP] Well-Known Member Vendor
    Rad
    LAX & LOGAN
    R E C H E L O N|AESTHETICS
    Our Passion is to Handcraft Custom Detailed Headlights
    Driven to Balance Aesthetics w/Performance
    GROUP BUY
    [ STARTS OCTOBER 8TH 2016 | ENDS NOVEMBER 1st 2016 ]
    HOW TO ORDER ?
    1. Email US Directly at RECHELON.AESTHETICS@GMAIL.COM
    2. FOLLOW US ON INSTAGRAM @ RECHELON.AESTHETICS
    3. INCLUDE YOUR TACOMAWORLD & INSTAGRAM SCREEN NAME & FULL NAME TO BE INCLUDED IN THE GROUP BUY
    A/M TOYOTA 2012-2015 RETROFITTED HEADLIGHTS
    [ STAGE I $850 BASE PRICE SHIPPED ]
    - Brand new aftermarket headlights
    - Morimoto Mini H1 7.0 projectors
    - Shroud Design of your Choice / Check The Retrofit Source's website @ (http://www.theretrofitsource.com/components/shrouds.html )
    - Blacked Out Paint Work ( BEZEL / BOWL / SHROUD / DTRL BLINKERS )
    - You can request to leave certain parts of the headlight chrome
    - Smoke Amber Reflector ( Can Leave Stock Amber )
    - Brand New 35W Morimoto ballasts
    - Brand New XB35 Morimoto Bulbs (We Recommend 4500k or 5500k)
    - Brand New Morimoto H4 Wiring Harness
    [ STAGE II $895 BASE PRICE SHIPPED ]
    - Brand New FX-R 3" Projectors
    OEM TOYOTA 2012-2015 RETROFITTED HEADLIGHTS
    [ OEM STAGE I $995 BASE PRICE SHIPPED ]
    - Brand new OEM headlights
    - OEM TRD PRO BLACK SMOKE / CHROME FACTORY COLOR SCHEME
    or
    [ OEM STAGE II $1050 BASE PRICE SHIPPED ]
    or
    ADDITIONAL OPTIONS FOR ALL STAGES
    - Passive Demon Eye / Subtle color accent inside the projector lens / Does not light up ( Color of your choice ) +$50
    - LED Demon Eye / Lights up inside the projector lens. (Color of your choice - Red, Blue, Green, Amber, or Purple) +$80
    - Halos (White & Amber Switchback / Front or Rear mounted) +$100 For One Set / +$180 For Both Front & Rear
    - RGB Color Changing Halos +$150 / +$270 For Both Front & Rear
    - RGB Color Changing LED Demon Eye +$150 ( Recommend to Wire them to a Switch/Button )
    +$270 For Both RGB HALO & RGB LED DEMON EYE
    - Clear / Light Clear Smoke / Dark Clear Smoke Replacement Reflectors. Replaces Stock Amber +$45
    - Black Chrome or Chrome Parking Light Corner +$20
    - Custom Color Matched Paint work / Our Professional Painter uses the best paint & clear product by GLASURIT. ( Pricing Varies )
    - Custom Art/Design Etching in Projector Lens +$45
    - OEM Upgraded Bulbs are Available to compliment your Choice of Projector (Pricing Varies)
    - 50W Ballasts instead of 35W +$10
    FOLLOW US ON INSTAGRAM AT
    IG = [ RECHELON.AESTHETICS ]
    Have your own OEM Headlights?
    Contact us directly as we can work out the details
  2. Oct 8, 2016 at 7:08 PM
    RAD
    Rad
    LAX & LOGAN
    HAVE YOUR OWN OEM HEADLIGHTS?
    WE CAN BUILD OFF OF THOSE AS WELL
    Follow us on Instagram
    RECHELON.AESTHETICS
    Questions/Inquries or Concerns
    rechelon.aesthetics@gmail.com
    FAQ
    Q. Is there a warranty?
    A. Yes. We offer a six month warranty on workmanship. TRS components follow the TRS warranty period. For example, 5Five Ballasts carry a 24 month warranty. 3Five ballasts carry a 60 month warranty. Etc... No hassle warranty. Shipping cost will be taken care of by TRS for U.S. transactions. For owners outside the U.S., you will be responsible for the shipping cost per TRS.
    The cost of shipping the headlight(s) to to me is the original owner's responsibility. I will be responsible for the cost of returning the warrantied headlight(s) to the original owner within the U.S. Sorry, if you are outside the U.S., you pay shipping both ways. This warranty is NOT transferrable. Any modifications and/or tampering of headlights will void the warranty.
    Q. How hard is it to install the headlights and wire harness once I receive them?
    A. If you have a slight bit of mechanical skills, then the installation will not be difficult. The wire harness is plug 'n play, no splicing of the OEM harness is required (unless your lights are equipped with LED Angel Eyes). The new, retrofitted headlight bolts up the same way your old one was removed. Wire harness instructions are included with your shipped headlights as well as online.
    http://www.theretrofitsource.com/pdf/trs_tech/Bi-Xenon MotoControl Relay Harness.pdf
    The OEM headlight aiming mechanism remains fully functional. After your retrofitted headlights are installed, some fine tuning will be required utilizing the OEM adjusters. Fine tuning is defined as matching both the left and right cut-off so that they are level with each other. As a rule of thumb, I recommend aligning the height of the cut-off to be horizontal with the upper trunk line of the average sedan.
    Q. Where can I learn more about retrofitting, projectors and HID bulbs?
    A. The Retrofit Source (TRS) has a tremendous amount of online material to enhance your retrofitting knowledge.
    http://www.theretrofitsource.com/trs_tech.php
    Q. What's the difference between the bulb colors?
    A. Kelvin Ratings: 3000K - Has a golden yellow output perfect for use in fog lights. The yellow light penetrates through snow, rain, and fog more effectively than white or blue light. 4500K - Has a slightly off-white output similar to that of sunlight. Most cars that come equipped with HID headlights from the factory use 4300K bulbs. If you want the most usable light, 4500K is the Kelvin rating for you. 5500K - A pure white output, no tinge of yellow, and no tinge of blue. 6500K+ As you move into the higher kelvin ratings, your light output will appear more bluish-purple in hue, but the bulbs won't be physically as bright. I do not offer 6500k bulbs. As HID bulbs age, they go through what is known as "color-shift". When the bulbs are brand new, the output is whitish-yellow and as physically bright as it will ever be. As the bulbs age with use, their output turns more pure white/bluish and also starts to dim a bit. That's why cars with factory 4500K bulbs that are 5+ years old look like they're running 5500K or higher bulbs.
  3. Oct 8, 2016 at 7:12 PM
    RAD
    Rad
    LAX & LOGAN
    [ 2015 DEFCONBRIX x RECH|CONBRIX SEMA BUILD ]
    THE STEALTH FSU
    [ UNIFORM INSPIRED BUILD ]
    Sect0r - brand new OEM headlights, G37R shroud with white halo in rear, flat black paint, smoked reflector
    temper - Brand new OEM headlights, G37R shroud w/ RGB halo, flat black paint, smoked reflector
    Idaholandho - brand new OEM headlights, anodized blue demon eye, bullet shroud, flat black paint, smoked reflector
    w/ flash on
    Dave P - Brand new OEM headlights, Panamera shroud with front and rear mounted amber halo, flat black paint, smoked reflector
    almoss - brand new OEM headlights, DTRL and Apollo 3.0 shroud left chrome, smoked reflector
    iHacker - Brand new OEM TRD Pro headlights (black chrome finish), Apollo shroud, everything left alone for an OEM look
    Flat black bezel, Shroud, Bowl, DTRL, and corner bowls all left chrome, amber halo, Apollo shroud
    TACOMAA6 - Brand new OEM headlights, Apollo 3.0 with white front mounted halo, red passive demon eye, smoked reflector, flat black paint
    Toyota Technical - Brand new OEM headlights, Panamera shroud with front and rear mounted amber halo, flat black paint, smoked reflector
    THE BUELL
    BLACK BEZEL | MAGNETIC GREY METALLIC BOWL & SHROUD | GUNMETAL PASSIVE DEMON EYE | CLEAR REFLECTOR |
    OEM SMOKE BEZEL | MAGNETIC GREY METALLIC BOWL & SHROUD | GUNMETAL PASSIVE DEMON EYE | CLEAR SMOKE REFLECTOR
    Uncle Cliffy likes this.
  4. Oct 8, 2016 at 7:42 PM
    RAD
    Rad
    LAX & LOGAN
    IMG_20160923_102036.jpg IMG_20160810_124454.jpg IMG_20160820_115510.jpg image.jpg IMG_20161006_101020.jpg IMG_20160825_172716.jpg IMG_20160826_171455.jpg IMG_20160830_104223.jpg IMG_20160809_122654.jpg IMG_20160926_145927.jpg image-1.jpg image-2.jpg image-3.jpg
    Boomkanani and Neutral like this.
  5. Oct 8, 2016 at 11:31 PM
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    So many choices!! How does one find all the options to choose from?
  6. Oct 9, 2016 at 11:15 AM
    dark vader trd pro
    dark vader trd pro Well-Known Member
    William
    NY
    2015 Tacoma Trd Pro
    i send u guys and email already however i dun even have an instangram accout to follow u guys
  7. Oct 9, 2016 at 11:48 AM
    gumpjr23
    gumpjr23 Well-Known Member
    2016 Double cab Off Road
    Definitely interested in a pair of 2016 fogs.
  8. Oct 9, 2016 at 5:00 PM
    RAD
    Rad
    LAX & LOGAN
    ^ @gumpjr23 Thanks for your interest Chris, please send us a direct email at rechelon.aesthetics@gmail.com
    @dark vader trd pro We'll respond back tomorrow Dark Vader. Thanks for your interest.
    @SonnyBones Isn't that a good thing? So many options and ideas to unleash your imagination. Check out all the pictures and get an idea of what you'd want to see in your own lights. Any ideas that you have, we can work together side by side to create something unique.
    Kind regards,
    R A D
    Biscuits likes this.
  9. Oct 11, 2016 at 2:00 PM
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    this might be the year I jump on these!
  10. Oct 11, 2016 at 3:33 PM
    RAD
    Rad
    LAX & LOGAN
    We'd love to be part of your build. . . Jump on it as we're not doing another GB for quite sometime.
  11. Oct 12, 2016 at 10:16 AM
    RAD
    Rad
    LAX & LOGAN
  12. Oct 13, 2016 at 7:54 AM
    Bchncar
    Bchncar Well-Known Member
    Sherry
    Indiana
    2013 Wrapped, Supercharged, Lifted Tacoma TRD
    ICON Stage II, Fuel Cleaver 20 x 9, Nitto Ridge Grappler 33 x 12.5, Magnuson Supercharger, Lund Bull Bar with LED, Magnum RT Nerf Bar, Spintech Exhaust, Full Body Wrap
    OK, I have bought my from me, to me Christmas present.....WOOHOO, can't wait to get these puppies installed!! Major pics will be posted when this is done..:santa::mudding:
  13. Oct 13, 2016 at 10:41 AM
    RAD
    Rad
    LAX & LOGAN
    SHERRY,
    We appreciate your purchase but we're inspired more by the story you shared with us. These are the reasons why we love doing what we do. We're honored to be part of this build and we look forward in honoring J.Bear. The fact it's going to be going on that 2013 White DC Tacoma, priceless. Thank you again for sharing. @Bchncar
    R A D
    Biscuits and Bchncar like this.
  14. Oct 13, 2016 at 11:49 AM
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    Dam that camo though! As always very high quality work!
  15. Oct 13, 2016 at 2:07 PM
    RAD
    Rad
    LAX & LOGAN
    @sytfu510 Ty for the kind words. Did someone say Quicksand Camo HL for their rig? :eek:
  16. Oct 13, 2016 at 4:47 PM
    dark vader trd pro
    William
    NY
    2015 Tacoma Trd Pro
    just pay for my set and:playball:
  17. Oct 13, 2016 at 7:00 PM
    RAD
    Rad
    LAX & LOGAN
    @dark vader trd pro TY for your purchase as we look forward in completing your headlights and fogs :thumbsup:
  18. Oct 14, 2016 at 10:27 AM
    RAD
    Rad
    LAX & LOGAN
    ALL EMAILS & INTEREST HAVE BEEN ANSWERED THIS MORNING
    THANKS FOR YOUR PURCHASE
    R A D
  19. Oct 15, 2016 at 9:16 AM
    RAD
    Rad
    LAX & LOGAN
    YOU CAN SEND US YOUR LIGHTS & BE PART OF THE GROUP BUY.
    R A D
  20. Oct 15, 2016 at 4:57 PM
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    Is it possible to use LED bulbs rather than the HIDs? I don't like HID ballasts, they are a PITA. Thoughts?
