[ R E C H E L O N | AESTHETICS ] 2 0 0 5 - 2 0 1 5 OEM TACOMA RETROFIT HEADLIGHT SERVICES
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by RAD, Mar 15, 2016.
  1. Oct 13, 2016 at 9:36 PM
    #601
    livelifetolive
    livelifetolive Well-Known Member
    SOBERDAVE
    Florida
    2009 4dr Tacoma TRD OR 4x4
    Thank you, much appreciated
    ChadsPride likes this.
  2. Oct 14, 2016 at 10:30 AM
    #602
    RAD
    RAD [OP] Well-Known Member Vendor
    Rad
    LAX & LOGAN
    ALL EMAILS & INTEREST HAVE BEEN ANSWERED THIS MORNING
    THANKS FOR YOUR PURCHASE
    R A D
  3. Oct 15, 2016 at 9:15 AM
    #603
    RAD
    Rad
    LAX & LOGAN
    YOU CAN SEND US YOUR LIGHTS & BE PART OF THE GROUP BUY.
    CHECK THE FIRST PAGE FOR INFO
    R A D
  4. Oct 16, 2016 at 8:40 AM
    #604
    ThomasMore66
    Dallas/Fort Worth & Durango
    These things keep looking better and better. Just FYI, I had one headlight flickering off/on last night and I knew it was a connection - had to be. Took me until this a.m. to check the ground wire...it was loose on the driver's side. So, Just check them periodically. I have an underhood light switch grounded to the same bolt and it had worked loose.
  5. Oct 16, 2016 at 8:41 AM
    #605
    ThomasMore66
    RAD, I have the RX350 lights from a couple of years ago. What replacement bulb should I buy? I just like to have them on hand.
  6. Oct 17, 2016 at 6:15 AM
    #606
    RECHELON
    RECHELON RETROFIT HEADLIGHTS
    RECHELON AESTHETICS
    SoCal to Portland
    DCX2
    PM'ed you
  7. Oct 17, 2016 at 10:17 AM
    #607
    RAD
    Rad
    LAX & LOGAN
    THE MONDAY
    EMAILS/INQURIES HAVE ALL BEEN ANSWERED THIS MORNING
    WE'VE GOT A GREAT AMOUNT OF ORDERS FOR THIS CURRENT GROUP BUY. TY EVERYONE FOR YOUR INTEREST & PARTICIPATION.
    GOT ANY IDEAS OR QUESTIONS? SEND THEM OUR WAY
    IF YOU WANT TO USE YOUR OWN HEADLIGHTS & BE PART OF THE GROUP BUY. YOU CAN ! ! !
    THE GROUP BUY ENDS OCTOBER 30TH.
    R A D
  8. Oct 18, 2016 at 9:23 AM
    #608
    RAD
    Rad
    LAX & LOGAN
    TUESDAY BUMP FOR THIS GROUP BUY ! ! !
    R A D
  9. Oct 19, 2016 at 10:23 AM
    #609
    RAD
    Rad
    LAX & LOGAN
    DON"T MISS OUT ON THIS GROUP BUY ! ! !
    [ ENDS OCTOBER 31ST 2016 ]
    LINK TO 2005-2011 GB
    https://www.tacomaworld.com/threads...oma-retrofitted-headlights-aesthetics.454783/
    LINK TO 2012-2015 GB
    https://www.tacomaworld.com/threads...oma-retrofitted-headlights-aesthetics.454787/
    HOW TO ORDER ?
    1. Email US Directly at RECHELON.AESTHETICS@GMAIL.COM
    2. FOLLOW US ON INSTAGRAM @ RECHELON.AESTHETICS
    3. INCLUDE YOUR TACOMAWORLD & INSTAGRAM SCREEN NAME & FULL NAME TO BE INCLUDED IN THE GROUP BUY
    A/M TOYOTA 2005-2011 RETROFITTED HEADLIGHTS
    [ STAGE I $750 BASE PRICE SHIPPED ]
    - Brand new aftermarket headlights
    - Morimoto Mini H1 7.0 projectors
    - Shroud Design of your Choice / Check The Retrofit Source's website @ (http://www.theretrofitsource.com/components/shrouds.html )
    - Blacked Out Paint Work ( BEZEL / BOWL / SHROUD / DTRL BLINKERS )
    - You can request to leave certain parts of the headlight chrome
    - Smoke Amber Reflector ( Can Leave Stock Amber )
    - Brand New 35W Morimoto ballasts
    - Brand New XB35 Morimoto Bulbs (We Recommend 4500k or 5500k)
    - Brand New Morimoto H4 Wiring Harness
    [ STAGE II $795 BASE PRICE SHIPPED ]
    - Brand New FX-R 3" Projectors
    [ Additional Option ]
    - Clear Blinker/DTRL Lens that replaces the slightly yellowed version. Clear lens by DKMoulds + $50
    OEM TOYOTA 2005-2011 RETROFITTED HEADLIGHTS
    [ OEM STAGE I $995 BASE PRICE SHIPPED ]
    - Brand new OEM headlights (with glass DTRL/turn signal)
    - OEM TRD PRO BLACK SMOKE / CHROME FACTORY COLOR SCHEME
    or
    [ OEM STAGE II $1050 BASE PRICE SHIPPED ]
    or
    A/M TOYOTA 2012-2015 RETROFITTED HEADLIGHTS
    [ STAGE I $850 BASE PRICE SHIPPED ]
    [ STAGE II $895 BASE PRICE SHIPPED ]
    OEM TOYOTA 2012-2015 RETROFITTED HEADLIGHTS
    or
    or
    ADDITIONAL OPTIONS FOR ALL STAGES
    - Passive Demon Eye / Subtle color accent inside the projector lens / Does not light up ( Color of your choice ) +$50
    - LED Demon Eye / Lights up inside the projector lens. (Color of your choice - Red, Blue, Green, Amber, or Purple) +$80
    - Halos (White & Amber Switchback / Front or Rear mounted) +$100 For One Set / +$180 For Both Front & Rear
    - RGB Color Changing Halos +$150 / +$270 For Both Front & Rear
    - RGB Color Changing LED Demon Eye +$150 ( Recommend to Wire them to a Switch/Button )
    +$270 For Both RGB HALO & RGB LED DEMON EYE
    - Clear / Light Clear Smoke / Dark Clear Smoke Replacement Reflectors
    Replaces Stock Amber +$45
    - Black Chrome or Chrome Parking Light Corner +$20
    - Custom Color Matched Paint work / Our Professional Painter uses the best paint & clear product by GLASURIT. ( Pricing Varies )
    - Custom Art/Design Etching in Projector Lens +$45
    - OEM Upgraded Bulbs are Available to compliment your Choice of Projector (Pricing Varies)
    - 50W Ballasts instead of 35W +$10
    2005-2016 LED FOG LIGHT HALO UPGRADE
    [ 10% OFF FOGS ]
    GROUP BUY PRICING
    [ 15% OFF FOGS ] GROUP BUY PRICING IF YOU PURCHASED A RETROFIT HL [ PAST CLIENT ]
    [ 20% OFF FOGS ] GROUP BUY PRICING IF YOU PURCHASE A NEW RETROFIT HL [ NEW CLIENT ]
    STARTS 10/9/16
    ENDS 10/31/16
    2005-2011 OPTION|PRICE
    1. DIODE DYNAMICS (JEWEL LED HALO ) RGB COLOR SHIFT
    $445 SHIPPED
    2. TRS MORIMOTO ( SMOOTH HALO ) RGB COLOR SHIFT
    $445 SHIPPED
    3. TRS SWITCHBACK XSB WHITE/AMBER HALO
    $395 SHIPPED
    OPTIONS
    1.) COLOR ACCENT INSIDE THE FOG LIGHT CAN BE PAINTED
    2.) RGB COLOR CHANGING HALO
    3.) WHITE|AMBER HALO
    [ 2005-2011 LED FOG LIGHTS PICTURED BELOW ]
    2012-2016 OPTION|PRICE
    $395 SHIPPED
    $395 SHIPPED
    $349 SHIPPED
    OPTIONS
    FOLLOW US ON INSTAGRAM AT
    IG = [ RECHELON.AESTHETICS ]
    Have your own OEM Headlights?
    Contact us directly as we can work out the details
  10. Oct 20, 2016 at 6:36 AM
    #610
    RECHELON
    RECHELON AESTHETICS
    SoCal to Portland
    DCX2
    BUMP
  11. Oct 21, 2016 at 9:44 AM
    #611
    RAD
    Rad
    LAX & LOGAN
    MORNING EVERYONE / IT'S FRIDAY
    ALL EMAILS & INQUIRES HAVE BEEN ANSWERED THIS MORNING.
    R A D
  12. Oct 21, 2016 at 7:39 PM
    #612
    ThomasMore66
    Never got it.
  13. Oct 22, 2016 at 6:33 AM
    #613
    RECHELON
    RECHELON AESTHETICS
    SoCal to Portland
    DCX2
    Should have gotten something just now. Will you please let us know if you don't? Thanks!
  14. Oct 22, 2016 at 7:37 AM
    #614
    ChadsPride
    Sponsored by TacomaWorld.com
  15. Oct 22, 2016 at 10:13 AM
    #615
    RAD
    Rad
    LAX & LOGAN
    ^ HA! You've been Liked by R A D
    Island Cruiser and ChadsPride like this.
  16. Oct 22, 2016 at 11:57 AM
    #616
    ChadsPride
    :yay:
  17. Oct 22, 2016 at 9:32 PM
    #617
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    Biscuits, jamiec and ChadsPride like this.
  18. Oct 23, 2016 at 6:40 AM
    #618
    ChadsPride
  19. Oct 25, 2016 at 8:51 AM
    #619
    RAD
    Rad
    LAX & LOGAN
    HOW TO ORDER ?
    or
    or
    or
    or
    - Halos (White & Amber Switchback / Front or Rear mounted) +$100 For One Set / +$180For Both Front & Rear
    - RGB Color Changing Halos +$150 / [B][B][B][B][B]+$270 For Both Front & Rear[/B][/B][/B][/B][/B]
    - Custom Color Matched Paint work / Our Professional Painter uses the best paint & clear product by GLASURIT. ( [I]Pricing Varies )[/I]
    [B]- 50W Ballasts instead of 35W [B]+$10[/B][/B]
    [B][B]2005-2016 LED FOG LIGHT HALO UPGRADE[/B][/B]
    [B][B][ 10% OFF FOGS ] GROUP BUY PRICING [/B][/B]
    PAST CLIENT ]
    [B][B][B]STARTS 10/9/16[/B][/B][/B]
    [B][B][B]&[/B][/B][/B]
    [B][B][B]ENDS 10/31/16[/B][/B][/B]
    [B]2005-2011 OPTION|PRICE[/B]
    [B]1. DIODE DYNAMICS (JEWEL LED HALO ) RGB COLOR SHIFT[/B]
    [B]$445 SHIPPED [/B]
    [B]2. TRS MORIMOTO ( SMOOTH HALO ) RGB COLOR SHIFT [/B]
    [B]$445 SHIPPED[/B]
    [B]3. TRS SWITCHBACK XSB WHITE/AMBER HALO[/B]
    [B]$395 SHIPPED[/B]
    [B]OPTIONS[/B]
    [B]1.) COLOR ACCENT INSIDE THE FOG LIGHT CAN BE PAINTED[/B]
    [B]2.) RGB COLOR CHANGING HALO[/B]
    [B]3.) WHITE|AMBER HALO[/B]
    [B][IMG][URL]https://www.tacomaworld.com/threads/r-e-c-h-e-l-o-n-aesthetics-2-0-0-5-2-0-1-5-oem-tacoma-retrofit-headlight-services.422025/attachments/1204213/[/URL][/IMG][/B]
    [B]2012-2016 OPTION|PRICE[/B]
    [B]$395 SHIPPED [/B]
    [B]$395 SHIPPED[/B]
    [B]$349 SHIPPED[/B]
    OPTIONS
    Biscuits and ChadsPride like this.
  20. Oct 27, 2016 at 9:46 AM
    #620
    RECHELON
    RECHELON AESTHETICS
    SoCal to Portland
    DCX2
    BUMP
