R150F 5 speed transmission and "push button" electronic T-Case replacement options?????
Discussion in '1st Gen. Tacomas (1995-2004)' started by hessian42, Dec 28, 2023.
  1. Dec 28, 2023 at 4:32 PM
    hessian42
    hessian42 [OP] Well-Known Member
    Max
    So my 2002 TRD 3.4L 5 speed is closing in on 400k miles and the O.G push button transfer case leaks like crazy (works fine) and my Marlin crawler R150F 5 speed (replaced by previous owner at 250k) also leaks and is not happy (3rd and reverse notchy to get into, famous whine). ***Yes, the complete clutch, flywheel, throwout bearing and master/ slave cylinders were all replaced with factory AISIN units 40-50k miles ago.
    I've been having a hard time trying to find a used "unicorn" push-button T-case and/ or deciding on rebuilding/ resealing what I got? Anyone been through the rebuild? kit cost? extra parts needed "while in there"? special tools (other than a press)?
    as for the R150F I don't trust the current trans or Marlin crawlers rebuild which lasted less than 100k miles before leaking/ whining. I see Yota1 offers a R150F for $1700 + $500 core (1 year warranty). And my local Autozone also offers a rebuilt unit for $1600 + $400 core (2 year warranty). Does anyone else offer quality rebuilt units?
    can I use R150F's and push-button T-Cases out of 4runners or other year/ gen tacos? I've read about the different input shaft length on the trans but are there other non compatible issues? Would a J-Shift T-Case bolt up to my stock driveline/ R150F and work other than loosing the push-button deal?
    Thanks for any input!
  2. Dec 28, 2023 at 4:40 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
  3. Dec 28, 2023 at 5:37 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Why not rebuild both units? If the t-case is just leaking, but otherwise operates fine, it probably just needs input/output shaft seals and/or flange seals.
    The r150 can be rebuilt by a competent shop for ~$1000, including all new seals and bearings. If there is any damage or wear to the gears or synchros, they can replace those all with little trouble.
    You could source a new/used t-case, it would need to be a push button with the same “options” as yours (4lo and neutral switches for ABS and e-locker functionality). Those switches can be added later if necessary. You can use a push button case from either a r150f or an A340, the only physical difference is the input shaft is 1/2” shorter on the A340 version. If you not pushing big tires and high horsepower, it’s not a problem.
    Switching to a j-shift t-case is quite a bit more involved, the 4wd ECM needs to be replaced and rewired with a control relay.
  4. Dec 28, 2023 at 7:21 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    If you end up going through with a J-shift case swap, I think you won't regret the final product. I own a 3rd gen 4runner with the push button case (auto trans) and an 03 Tacoma with the J-shift, and the J-shift is so much better when you're going in and out of 4wd frequently.
    But sounds like fixing your current case is certainly the easier route.
