R156f 2nd gen compatibility
Discussion in '4 Cylinder' started by Depoxy, Oct 26, 2016.
  1. Oct 26, 2016 at 9:39 AM
    Depoxy
    Depoxy [OP] Well-Known Member
    SoCal
    2010 Regular Cab 5-speed 4x4
    URD S/S, Eibach pro-truck @ 0.8" lift, hanook 265/75r16 AT
    Does anyone know if the newer r156f transmission from the 2.7l third gen's is compatible with 2.7l 2nd gen's that came with a r155f transmission? My transmission is going to need a rebuild pretty soon but considering the newer transmission for the slight improvements and better gear ratios for oversized tires. I tried searching TW and google but couldn't find anything about backwards compatability.
    Kees and GDT like this.
  2. Oct 27, 2016 at 7:26 AM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    What's wrong with your current transmission?
  3. Oct 27, 2016 at 11:51 AM
    Depoxy
    SoCal
    Nothing too bad. Mostly an input shaft whine and a rattling throwout bearing. I'm not itching to pull it, but researching options for the day it decides to give up on life.
  4. Oct 28, 2016 at 8:16 PM
    toyodajeff
    jeff
    06 reg cab sr5
    Probably just be easier to regear it if you want the lower gears, probably be pretty expensive for a new trans or a trans from that new of a vehicle at a junk yard.
  5. Nov 1, 2016 at 8:15 PM
    downhillbik3r
    downhillbik3r Well-Known Member
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Kings, 4.88's, ARB, +2 LT, DMZ SUA
    The r156f and the r155f use the same housing.
    GDT likes this.
  6. Nov 3, 2016 at 4:17 PM
    SnowB0und
    SnowB0und Well-Known Member
    4cyl 4x4
    Whats the difference in the ratios? I've heard it has better 1st gear syncros.
  7. Nov 3, 2016 at 4:59 PM
    Depoxy
    SoCal
  8. Nov 13, 2016 at 7:25 PM
    SnowB0und
    4cyl 4x4
    I'd love those ratios, way better for starting off on a boat launch!
  9. Aug 16, 2017 at 11:03 AM
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    The more I think about this, the more I'd like to do this swap. Definitely would appreciate the lower first and second gears. I'd have a hard time pulling my tranny since it hasn't given me any trouble, but it's still tempting. I wonder if I'd be able to sell my r155f in good condition to recoup some of the cost.
  10. Aug 16, 2017 at 11:52 AM
    Silverbullet8
    Silverbullet8 Active Member
    Upstate New York
    2012 2.7 5spd 4wd regular cab
    2 inch lift+285 tires custom catback exhaust Volant CAI PRO-M Tune
    If I remember correctly the first gear on the R156f has a triple cone synchronizer where as the R155f does not.
  11. May 21, 2023 at 12:53 AM
    GDT
    Anybody do this swap yet? My r155f is starting to make some noise.
  12. May 21, 2023 at 6:50 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    @jowybyo is running one in his second gen. I have one that i'm planning on swapping in here in the next month or so
    jowybyo likes this.
