RA60 bellhousing diagram? Removal?
Discussion in 'X-Runners' started by Myk-07XR, Mar 3, 2022.
  1. Mar 3, 2022 at 5:32 PM
    Myk-07XR
    Myk-07XR [OP] Member
    Michael
    O7 X-Runner
    On my 2007 X runner I need to replace the transmission bell housing because of a broken interior quill. Does anybody know where I can find a diagram of the bellhousing and instructions on removing it from the rest of the transmission?
  2. Mar 4, 2022 at 5:40 AM
    Superloki24
    Superloki24 Well-Known Member
    Windsor, ON
    '14 X-Runner
    TRD SC, TRD CAI (Gen 1), Full URD Spec-U Exhaust, UCON EMS, , URD Lightweight Steel Flywheel, URD Stage 3, URD Trac Bar, OEM Oil Cooler, Detroit Tru-Trac, Truxedo Titanium Cover, 76mm Throttle Body, XII Performance drop, QA1 Rear Shocks, 4x4 Rear Leaf Springs.
    I had to do this same thing. Long story short is that the way this transmission is designed, you have to start from the back of the transmission and take it apart piece by piece until you are left with just the bell housing. No easy way to take it off otherwise. But if you are pretty handy, it can easily be done in a day.
