Rab89's Tacoma sleeping platform
Discussion in 'Other Builds' started by rab89, Mar 22, 2010.
  1. Mar 22, 2010 at 3:44 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    well, I'm headed to Texas at the end of the week from B.C Canada, and I needed a place to sleep, the back of the truck sounded great!
    I didn't want a super enclosed frame that was hard to see into, because I have to cross the border, and that may have been a hassle.
    here is the frame, I used a thin piece of plywood on the bottom for rigidity.
    I used 1- 2x12x12 piece of wood for the side rails, cut in half to fit the 6 foot bed.
    I had some cedar 2x4 lying around, so I used that to make it even tougher,
    I used 3 pieces laying horizontally across the top, to maximize storage space underneath, and at the front near the cab, I put 2 pieces vertically, again for rigidity.
    I also wanted to be able to take the top sheet off easily for when I get to the border. I used a 4x8 foot piece of 5/8 plywood for the top, I wasn't sure it would be wide enough, but as you can see there is only about 4 inches on either side of free space, which leaves room to stuff things down the sides for storage.
    To secure the top sheet from sliding around, I drilled 2 holes at the back end, through the top sheet and into the 2x12, then I cut some big stakes in half and cleaned up the ends. I can easily slide them in an out to remove the top sheet.
    by using the 2x12, I was able to maximize storage underneath, giving me a total of 10 inches for my suitcase.
    more headroom would have been nice, but I needed room to store my stuff while sleeping (gf will be with me, so the bags have to go underneath).
    well there you have it, I may cover it with some outdoor carpet before I go, we'll see.
    hopefully this helps the next guy in building a custom sleeping platform.
  2. May 11, 2010 at 4:59 PM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
  3. Apr 8, 2014 at 1:22 PM
    ScampTramp
    ScampTramp Active Member
    Robert
    AZ
    TRD
    STOCK as a Rock!
