Rack and Pinion AGAIN??
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03coma, Jul 6, 2010.
  1. Jul 6, 2010 at 5:07 PM
    03coma
    03coma [OP] Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Just had the stealer install a new Rack and Pinion in May (extended warranty) on my 03 taco, but after picking it up the steering was very loose feeling and now I have a banging when you turn the wheel about 1/4 turn.
    I gave them new outer tie rods to install too.
    Just took it back and bitched, and they tell me the new rack is shot and I need the yoke in the steering column…WTF?
    What's going on with Toyota?? never had these kind of problem before.::(
  2. Jul 6, 2010 at 5:15 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    Who was the stealer in NJ? And why was the complete rack replaced? Leakage?ETC.
  3. Jul 6, 2010 at 5:27 PM
    03coma
    New Jersey
    2015 DCSB TRD, SR5
    Caldwell Toyota, They didnt tell me just said they were replacing it under parts warranty. no leaks
  4. Jul 6, 2010 at 5:31 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    did they put new bushings in? i friend of mine just did new mount bushings in his first gen steering rack they were making all sorts of problems. try running the truck and have someone turn the wheel back and forth and you crawl underneath and see if you can see the steering rack assembly shifting. if so the bushings are shot. energy suspension makes an awesome bushing replacement kit.
  5. Jul 6, 2010 at 5:32 PM
    Mush Mouse
    mush
    2013 SR5
    Did you complain to them that you had loose steering?Cause usually they just dont go and replace a Rack without some justification for doing so? Usually they'll replace it if the owner complains of loose steering(worn out bushings) or has leaking PS fluid ,they replace with a Remanufactored unit.
  6. Jul 6, 2010 at 5:34 PM
    Mush Mouse
    mush
    2013 SR5
    Exactly I had loose steering feel checked the bushings had movement,replaced with Energy Suspension Urethane and also did Sway bar bushings Urethane,cost $325 with Alignment. Not steering like a Sportscar but better than before
  7. Jul 6, 2010 at 5:35 PM
    03coma
    New Jersey
    2015 DCSB TRD, SR5
    ttylerr that’s the problem the original rack had. The bushing on the driver’s side blew out and the rack was jumping off the frame. But Toyota didn’t sell the bushing by itself and the extended warranty was still good, so they replace the entire rack and pinion.
  8. Jul 6, 2010 at 5:38 PM
    Mush Mouse
    mush
    2013 SR5
    If they replace the rack again,buy yourself some Energy Suspension bushings online about $30 or less and tell Yota to use them instead of the factory rubber ones:wink: and also get the sway bar ones and replace them yourself real easy to do 10mm socket,and some Penetrating oil big difference
  9. Jul 6, 2010 at 5:39 PM
    03coma
    New Jersey
    2015 DCSB TRD, SR5
    Now the steering feels loose and I have a banging in the steering column, if you hit even a small pot hole the steering wants to go all over the place.
    They are replacing the rack and pinion and the yoke now. hope this solves the problem.
  10. Jul 6, 2010 at 5:41 PM
    03coma
    New Jersey
    2015 DCSB TRD, SR5
    Mush I have to look into that now, thanks for the info.
  11. Jul 6, 2010 at 5:43 PM
    Mush Mouse
    mush
    2013 SR5
    Cool good luck,If you dont like the service at Caldwell you can go to another Stealership to get a satisfying job done since your under extended warranty,sounds like they F'ed something up on the replacement
  12. Jul 7, 2010 at 6:01 PM
    03coma
    New Jersey
    2015 DCSB TRD, SR5
    4th time's a charm, Replaced Rack and Pinion, Steering Lock, Intermediate Shaft, Steering Shaft and Yoke. The Steering is TIGHT.
  13. Jul 12, 2010 at 8:59 PM
    toy02ota
    toy02ota Local TW dissenter
    Brownsville, TN
    2005 Chevy Silverado
    Dang! Youve been a member since 06 and only 130 posts? Thats crazy to me. I guess I have the making of yet another post whore :eek:
