Rack and pinion and ujoints for front and rear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MACKT28, Aug 20, 2022.
  1. Aug 20, 2022 at 7:58 AM
    MACKT28
    MACKT28 [OP] Well-Known Member
    2006DCLB
    Heretic Ditch lights Toyo Open Countrys AT2 HI VIS OVERLAND RTT
    Just got out of the dealership and they told me I needed to replace my rack and pinion. I did see that I have a slight leak on the passenger side. Wondering if this is something I can do myself by chance. They quoted me $2037 to do the job. They also stated that three of my ujoints on my driveshaft are blown going to the rear diff and that job was quoted at $1618!!! Just wanted to get some insight on everyone's opinion.
  2. Aug 20, 2022 at 8:19 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Find a good local mechanic. I've seen a couple of places online where you can buy a brand new rear drive shaft assembly for about $400. You could install yourself in less than a couple of hours with minimal hand tools.
    Not sure about the rack, but I have seen a couple of videos on YT showing how to change one.
    deanosaurus likes this.
  3. Aug 20, 2022 at 9:02 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    winkel likes this.
  4. Aug 20, 2022 at 11:45 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Confirm that the rack’s internal seals are leaking and that it is not oil dripping down from above. If it is leaking, I have had success significantly reducing rack/pinion leaks with ATP AT-205.
    The rear driveshaft in a double cab has three u-joints and a center bearing. I’m sure the quote includes all four components, but, the parts are only about $200 for good quality Spicer components.
  5. Aug 21, 2022 at 4:40 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    As others have said, a remove/replace of a driveshaft is not difficult and can be done in a couple of hours in your driveway for far less than half the cost the dealer is quoting, even if you literally have to buy the tools to do it - even a cheap compressor and impact gun. If you don't use a complete driveshaft and instead replace the u-joints in your existing shaft, the cost is more like a quarter the quoted price or even less if you just rent a ball joint press.
    A rack rebuild is significantly more complex - removal is notoriously a pain in the ass on these trucks and the rebuild, from what I have read and heard from those who have done it, is also finicky. I do almost all of my own wrenching but when I blew my rack, I opted to have a local mechanic replace with OEM and I'll be rebuilding the old one at my leisure to keep on hand for next time.
    winkel and SpanishTaco like this.
