Rack And Pinion Bushing Replacement, raise truck?
Discussion in '1st Gen. Tacomas (1995-2004)' started by lonzorizo, May 9, 2011.
  1. Mar 8, 2013 at 9:35 AM
    BonesD
    BonesD Member
    Austin Texas
    99 Pre runner 167,000miles
    Reply to my own post. Went and bought a 22 mm socket that fit just right and I broke my breaker bar off at the knuckle. I am afraid to put much heat on this bolt as I don't want to destroy the bushing that is in there and not be able to replace it Cra_! Figures it is the last bolt holding everything together. I might have to put it back together and take it to a shop with air tools and have them loosen it for me. What a pain!
  2. Mar 8, 2013 at 11:08 AM
    BonesD
    BonesD Member
    Austin Texas
    Ok, I am old and can't see. The 22 mm nut on the middle of the rack is welded to the frame. The bolt comes off from above. I am quiting for the day since it's raining and I am disgusted with my self.
  3. Mar 8, 2013 at 4:24 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    glad you figured that out. YOU do not want to bust that loose.
  4. Mar 8, 2013 at 7:36 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Don't be too hard on yourself. I didn't break my breaker bar but I did try to break that nut loose. :eek:
