rack and pinion bushing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco89, Jun 8, 2011.
  1. Jun 8, 2011 at 9:36 AM
    Taco89
    Taco89 [OP] Well-Known Member
    Nik
    Charlotte, NC
    2013 4x4 Super White DBL Cab TRD Sport
    I lifted my truck a couple months ago and now it seems that my rack and pinion bushing is being worn out. I have an 08 tacoma...anybody have any problems with this after lifting your truck?
  2. Jun 8, 2011 at 9:54 AM
    kite
    kite Well-Known Member
    Squamish, BC
    Red Truck
    What symptoms is it showing?
  3. Jun 9, 2011 at 6:14 AM
    Taco89
    Nik
    Charlotte, NC
    its making a cracking noise sometimes when i turn my wheel while driving plus when i put it in reverse and then brake it makes a clanking noise like something is loose and when i put it back in drive and brake again i hear it again...i had someone check it out and he said it was my rack and pinion bushing but i dont know much about trucks/cars so i dont know if thats what the problem is. He said it was because of my bigger tires that is causing it to wear out.
  4. Jun 9, 2011 at 7:55 AM
    Taco89
    Nik
    Charlotte, NC
    So if it isn't the bushing, do you have any idea where the cracking noise is coming from?
  5. Jun 9, 2011 at 1:11 PM
    Taco89
    Nik
    Charlotte, NC
    Alright thanks I'll check it out
  6. Jun 9, 2011 at 1:22 PM
    KColoTaco
    KColoTaco Well-Known Member
    Kevin
    N. Colorado
    08 TRD O/R DC
    3 inch OME complete lift, Light racing UCA's, Bed comp. locks.
    The one metallic clank in reverse then one going forward is the brakes. It's a toyota thing.... As for the R/P bushing, there should not be excessive slop when changing load direction in the stearing wheel. If there is then it might be a possibility.
  7. Jun 9, 2011 at 1:54 PM
    Taco89
    Nik
    Charlotte, NC
    So there's nothing I can do about the clank? That's what I was most worried about
  8. Jun 9, 2011 at 2:24 PM
    Taco89
    Nik
    Charlotte, NC
    Haha I know right, it's so annoying.
