Rack and Pinion Has Play Inside the Boot??
Discussion in '1st Gen. Tacomas (1995-2004)' started by 12guns, Jan 6, 2010.
  1. Jan 6, 2010 at 5:32 PM
    12guns
    12guns [OP] Member
    Evan
    Rville, AR
    96' Tacoma 4x4
    So I thought I had alot of play in the inner tie rod end, when I got the boot off, turns out the shaft in the rack and pinion w/ the teeth cut out is moving up and down slightly. The inner tie rod end is tight w/ no play.
    So, bad rack and pinion? I replaced w/ used years ago, guess it may be time again. Any way to rebuild these? Looks like some power steering fluid may have leaked inside the boot. Is there a seal that can be replaced and "tighten" up the shaft? Any help would be great. Thanks
  2. Mar 14, 2010 at 7:47 PM
    Helison
    Helison Member
    Casey
    96' SR5 TRD
    Throttle Body, 4 inch Fab-tech Lift, 33" Hankook Tires, 2x12" Volfenhag subs.
    I'm having the same problem with my steering rack, I've been trying to figure out your same questions as far as tightening something but haven't found anything. I've been thinking about just replacing the whole rack, did you replace yours youself or had someone do it?
