Rack and Pinion O Rings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mattsyota529, May 10, 2022.
  1. May 10, 2022 at 9:46 AM
    Mattsyota529
    Mattsyota529 [OP] Active Member
    2009 Tacoma Prerunner
    Hello all, I recently bought a new rack and pinion for the Taco. Got it from 1 a auto and unfortunately it didn't come with the o rings that go on the rack and the lines. Does anyone know where I can just buy the oem orings? Or have a part number for the oem ones? Autozone sells them but it's 60 dollars. It's for a 2009 Prerunner 4.0. Thanks in advance
  2. May 10, 2022 at 11:18 PM
    TacoTuesday1
    SD CA
    Are they O-rings or sealing washers?
    Because sealing washers can be size matched to replace for cheap, or worst case scenario heat them to re-expand the metal to re-use, such as carefully with MAP gas torch
