Rack and Pinion & Other Tasks?
Discussion in '1st Gen. Tacomas (1995-2004)' started by billybonez, Feb 25, 2025.
  1. Feb 25, 2025 at 1:44 PM
    billybonez
    billybonez [OP] Member
    Sacramento, CA
    2002 3.4L 5VZFE M/T 4WD XTRACAB
    I am planning and buying parts for a rack and pinion replacement on my 2002 4x4 Taco. I am replacing the assembly, outer tie rods, and sway bar bushings. I was thinking I would clean the PS pump and do a flush of the system as well.
    Does anyone have any recommendations of other items I may want to replace / check while I have the assembly removed from the truck?
  2. Feb 25, 2025 at 2:51 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Got aftermarket rack bushings on your list?
  3. Feb 25, 2025 at 3:51 PM
    Texas Pete
    Texas Pete New Member
    ray
    1997 Tacoma
    I just started having trouble with my steering on my 1997 Tacoma 2wd . Squeaks when I turn the
    steering wheel and won't return to center.
  4. Feb 25, 2025 at 4:20 PM
    billybonez
    Sacramento, CA
    No, they are a pain to press in, and I am not a fan of polys.
    MadNachos[QUOTED] likes this.
  5. Feb 25, 2025 at 5:00 PM
    MadNachos
    I agree in most situations, but it's a good fit here, and they just pop in. Nothing wrong with new OE ones though.
    Wulf and billybonez[QUOTED][OP] like this.
  6. May 17, 2025 at 11:07 PM
    billybonez
    Sacramento, CA
    Decided to go that way after all. I was looking at sets from Whiteline, Total Chaos, and LC Engineering. They look completely identical to me except that Total Chaos' set is in red. I assume you have replaced these bushings before, what brand (rebrand) did you go with, and any particular reason other than cost or availability?
  7. May 18, 2025 at 6:13 AM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Recently replaced my rack. Swapped out the garbage bushings that came with the reman rack (used ES). Replaced that rubber rag joint/intermediate shaft - the piece that connects the rack to the steering column. Replaced both return and pressure lines too. The inners that came on the reman rack also were crap so I put 555s inner and outers.
  8. May 18, 2025 at 6:47 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Idk if it’s too late, but even with an oem replacement rack the bushings should be replaced - I was really disappointed seeing how much flex there was after only 3-4 years on my wife’s 4runner that isn’t on big tires or off-roaded.
    Toyota Time with Timmy has a good video on cleaning the power steering reservoir screen and rebuilding your return line with bulk power steering line is a good and easy thing to do when the system is empty. I got a leak that looked like the cv / diff seal on the drivers side because it leaked on the cv and slung fluid everywhere.
    billybonez[OP] likes this.
  9. May 18, 2025 at 9:30 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    The power steering reservoir cleanout is not too difficult. The airbox does not need to come out for it. A messy job though
  10. May 19, 2025 at 2:32 PM
    MadNachos
    I actually haven't replaced mine yet, but I used to autocross a lot and have replaced them on a ton of cars while swapping bars. I usually go with the softer ones if possible for the street, but on these, I wouldn't expect to notice much difference (if any) between the brands. I like whatever doesn't squeak.
