rack and pinion problems...
Discussion in 'Suspension' started by DaytonLax14, Sep 29, 2010.
  1. Sep 29, 2010 at 12:59 PM
    DaytonLax14
    DaytonLax14 [OP] Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    Hopefully this is the right section but anyways...
    I went to Firestone to get a front wheel alignment but come to find out, my "rack" (what the guy kept referring to it as) is loose. When the guy at firestone who was working on my truck gave my tire a shake, the rack would wiggle back and forth. They wanted around $800 to fix it, and I don't have $800. How severe of a problem is this? Would I be able to fix it myself once I got the part/s?
  2. Sep 29, 2010 at 1:06 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    wait so the rack moved when the tire moved.... am i retarded or does that make perfect sense....
  3. Sep 29, 2010 at 1:09 PM
    DaytonLax14
    Corey
    Ohio
    the part that connects to the tie rod and goes into the housing moved. You can only see it move if you slide the rubber boot down so you can see it
  4. Sep 29, 2010 at 1:15 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    The rack is bolted in place. If the whole assembly is moving, tighten the bolts.
    If the assembly needs to be replaced, you can pick up a new one for $310 after the core return from rockauto.com.
    Get under your truck and turn some wrenches. :)
  5. Sep 29, 2010 at 1:18 PM
    dagul
    dagul Well-Known Member
    SoCal
    01 RR SR
    Try upgrading to urethane bushings in your steering rack since that would be the cheapest course of action...
  6. Sep 29, 2010 at 1:19 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    if shit is broken, this guy would know!!! :D
  7. Sep 29, 2010 at 1:20 PM
    malander
    max
    01 limited trd 4x4
    i guess that confirms it... im retarded lol
  8. Sep 29, 2010 at 1:20 PM
    DaytonLax14
    Corey
    Ohio
    The whole assembly isn't moving, but the part that comes out of the assembly and then connects to the tie rod is moving.
  9. Sep 30, 2010 at 11:21 AM
    DaytonLax14
    Corey
    Ohio
  10. Sep 30, 2010 at 11:31 AM
    TacomaDan
    TacomaDan Don't go off ninjin
    Daniel
    Woodland, CA
    1996 Toyota Tacoma Fully Not Loaded
    Love, Cobra 29 LTD BT CB w/ A2000 Highgear antenna, FOX/Fabtech Coilovers, Magnaflow
    I think there was a write up on this a while ago. There is a tensioner bushing in there that wears out and then you will have super sloppy steering. For the life of me I cannot find it. See that ginormous bolt to the left of the mounting bolt in your video? In there is a bushing that wears out over time
  11. Sep 30, 2010 at 12:01 PM
    DaytonLax14
    Corey
    Ohio
    do you know where i can get a new bushing?
  12. Sep 30, 2010 at 12:09 PM
    mjp2
    NJ
    Yes...
    Did you check rockauto's site? The bushing set is listed right there along with the rack assembly. $20 for the full set.
    We'll help you out but you gotta do your part to help yourself as well.
  13. Sep 30, 2010 at 12:12 PM
    DaytonLax14
    Corey
    Ohio
    Should I replace all 3 bushings or just the driver's side
  14. Sep 30, 2010 at 12:13 PM
    mjp2
    NJ
    If you're already tearing into the assembly, replace everything. If 1 part wore, everything else is sure to follow shortly thereafter.
  15. Sep 30, 2010 at 12:15 PM
    DaytonLax14
    Corey
    Ohio
    I did some research on google and everyone seems to reccomend the energy suspension bushing kit. do you know if i can get that at an auto parts store like auto zone or do i have to order it online
  16. Sep 30, 2010 at 12:24 PM
    mjp2
    NJ
    Depends on how much you like spending money. A store that has to special order the parts will be more than happy to charge you more.
  17. Oct 1, 2010 at 9:49 PM
    TacomaDan
    Daniel
    Woodland, CA
    O I'm not talking about the mounting bushings. Here's what you want:
    Read up and do it!
  18. Oct 7, 2010 at 11:49 AM
    DaytonLax14
    Corey
    Ohio
    okay thanks looks like I just need a new guide
