Rack and pinion replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by HomesD86, Feb 19, 2018.
  1. Feb 22, 2018 at 3:23 AM
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    Haha well it IS a nice write-up =P
  2. Feb 22, 2018 at 3:27 AM
    Russianman92
    Dunwoody GA
    And yes, I got what you are saying. The China racks come with inner tie rods? That's where I think the disconnect is. I see those 2 pics that say the china racks are crap and I see broken...inner tie rods... I was a bit confused as those items broken aren't the actual rack failing.
    NOT saying china racks aren't crap ( I wouldn't buy one myself) I would go OEM only TBH, but I was just trying to match the failure in the photos to the discussion.
    Dirty Pool[QUOTED] likes this.
  3. Feb 22, 2018 at 7:12 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Got it.
    The ITR's pictured came on the racks, a Rack Doctor rebuild and a "new" China knock off. Intended to show what goes into these things as far as quality. The China racks have shown numerous failures, from internal components to very dangerous assembly mistakes. Just like a rebuild they seem to either work for a few years or not. Rebuilds of OE racks can be assumed to be "clean/inspect/re-seals" as the cost of just about any hard parts beyond cheap ITR's will exceed the pricing point in a second. Price a pair of wholesale OE ITR's and it's pretty clear truly OE parts are not going into rebuilds.
    The CVJ folks charging $100 for the newer rack guide seems like a joke, anyone can buy it from Toyota for less than that and there is no additional labor. This is a part that should be replaced in a rebuild any way and not an additional cost. They have a good rep for now but and have edged out Rack Doctor as the current online favorite, things need to be kept in perspective.
    :deadhorse:
    Russianman92 and otis24 like this.
  4. Feb 22, 2018 at 7:15 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    You’ve definitely made me re-evaluate my plans for when I replace my rack whenever it finally decides to go.
  5. Feb 22, 2018 at 7:23 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    All OE service replacements come with the new guide/cap/spring and I have no proof but I think the mount bushings have also been improved. They seem much harder than previous years, harder than poly replacements.
    otis24[QUOTED] likes this.
  6. Nov 19, 2019 at 4:34 AM
    Bolsado
    Bolsado Active Member
    98 SR5 Xtracab 4x4
    Is the OEM available even. Had a cluster with a capitol "F" on a brake booster chase Toyota no longer makes them. It looks like according to my review of Toyota online parts the R & P for a 98 is discontinued.
    Anyone know if this is correct????
  7. Nov 19, 2019 at 8:27 AM
    rickyg2008
    rickyg2008 Well-Known Member
    I went with an oem rack . No issues.. I did upgrade the bushings to energy suspension ones. Reading that seems to be the week point.
    It’s actually a really fun job
  8. Oct 19, 2020 at 11:42 AM
    CaliboyColoradolivin
    CaliboyColoradolivin Well-Known Member
    Denver, CO
    2018 Cement Grey Toyota Tacoma DLCB, V6, 4WD, Off-Road Package
    Bilstein 5100's, OME 885, Headstrong 3 Leaf Progressive, Pro Comp Wheels, 265/75/16, BAKFlip MX4 Tonneau Cover
    Sorry for digging this up. Based on the comments are we saying to stay away from the Rack Doctor? I have a 98' limited 4X4. Noticed some saturation on the right by R&P and a little on CV axle. I just replaced the left CV axle and all is good. Getting same saturation as before on left side but it was in fact the CV. However, I am pointing more towards this being R&P. I put in extra power steering which i will watch for a week to see if this is the cause.
    According to Rack Doctor, this is everything that comes with the product. Are there any other items that will be NEEDED for this project?
    • All new seals
    • All new O rings
    • All new Teflon rings
    • All units come complete with inner tie rods and boots
    Thank you for any help.
  9. Oct 19, 2020 at 1:02 PM
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    I bought a rack from detroit axle for my BMW years ago, and it was fine. (ebay)
    I bought a rack from detroit axle for the truck 2 years ago, maybe 20k miles, and its leaking like crazy.
    The lift tires, and hard driving doesnt help, but they are honoring the lifetime warranty. Yeah it sucks I have to replace it , but I'm getting the new one at my doorstep in a couple days. Just paid the shipping fee.
  10. Jun 19, 2024 at 5:33 PM
    Lord Kanti
    Lord Kanti BlackJack Taco
    SoCal
    2002 Double Cab 4x4 SR5 TRD Blackout
    Deck plate gray wire Blackout De-badge Lift Tires
    How do you get the bolt out of the driver side bushing on a 4x4? Do I just leave it in there and pull the rack toward the bed and then slip the new bushing between the bolt and the loose rack? I'm not trying to swap the whole rack unless I have to and right now, I am just trying to swap bushings on a gen1 4x4 and that bolt will NOT come free without removing other parts.
  11. Jun 19, 2024 at 10:31 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    On mine, the bolt head was a flanged head. And one part of the flange was hitting the front diff, not allowing it to be pulled out completely. Is that what you are facing?
    We took a grinder to the flange. Ground it down just enough to allow it to pass by the diff casing.
  12. Jun 20, 2024 at 2:45 AM
    Lord Kanti
    SoCal
    Yeah, I'm tempted to do this, or cut it and install a new bolt backwards. I managed to pull the whole rack backwards enough to get a bushing in without removing the driver-side bolt, but the angle to return the rack is too tight to slip it over the bolt. I'm going to pop the driver side tie rod out tomorrow to try and get a bit more play and see if that does the trick. I finally read the directions that came with the bushings, and they also mentioned tie rod removal, so hopefully I get just enough wiggle room to not have to cut the bolt.
    Do you have any tips for grinding the bolt if it comes to that? I'm pretty sure I have fresh discs if needed.
  13. Jun 20, 2024 at 7:35 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    I went with low range and it was a terrible deal. They show an image of the upgraded guide on the rack and pinion. When asked they said it was. I received it and it was not what they had mentioned. I paid $150 to send it back and get a refund and just went to McGeorge Toyota and bought OEM. I'll never deal with low range again but that's just my experience with them.
