Rack for ~500lb. motorcycle off the back?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 5efvz, Oct 2, 2022.
  1. Oct 2, 2022 at 2:04 PM
    5efvz
    5efvz [OP] Well-Known Member
    Thinking of making a rack for a motorcycle that will be attached to the truck's frame at the rear and sit behind the tailgate. Will this be too much weight off the rear? Will my truck do a wheelie?
  2. Oct 2, 2022 at 6:24 PM
    02hilux
    Planet: EARTH
    :annoyed:
    Your frame won't be happy. Especially the thin C channel piece between the cab and bed, where the fuel tank crossmember mount to.
    Nessal and 5efvz[OP] like this.
  3. Oct 2, 2022 at 7:15 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    That's pretty heavy. Why not put moto in the bed and use a cargo rack in the hitch instead?
    5efvz[OP] likes this.
  4. Oct 2, 2022 at 7:38 PM
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    A first gen has a maximum trailer tongue rating of 600lb. As a trailer has its own axle this weight/load will stay consistent when driving down the road.
    500lb motorcycle + 50lb (minimum) for a carrier is essentially the weight rating by themselves. Worse though, it is cantilevered from the truck and free to bounce up/down/left/right as you go down the road. If you hit a hard bump it will easily be twice the static load. That’s not what the hitch and your frame are designed to for.
    I’d recommend the bed as others have said or a small tow-behind trailer.
  5. Oct 4, 2022 at 9:48 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Not a good idea....
  6. Oct 4, 2022 at 9:53 PM
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    Smaller bike an option? My CRF450X did great on my Versahaul (an awesome hitch hauler), but 500lb on top of that rack is asking for trouble on a Tacoma.
  7. Oct 4, 2022 at 10:00 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Yes and occasionally yes (...but who needs steering control ALL the time anyway?!)
  8. Oct 4, 2022 at 10:45 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Someone mentioned possible troll, at this point now I believe it :burp:
