Rack issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Armament, Nov 26, 2019.
  1. Nov 26, 2019 at 5:39 AM
    Armament
    Armament [OP] Well-Known Member
    Nick
    Albuquerque, NM
    2012 Tacoma Double can 4wd
    Full Camburg LT front suspension, King coil overs, Rough Country spindles, King 2.5 reservoir rear shocks, OME Dakar spring packs, T100 E-locked rear axle, 35x12.5x17 tires, Fiberworx fenders and bedsides.
    Yes, I searched and I did a google search too. Didn’t find “exactly” what I was looking for so I’ll ask.
    2012 taco, long travel, 35” tires. I just noticed that when the truck stopped, engine running, I get about a 1/3 turn of the steering wheel in either direction then it hits a wall and feels like it’s manual steering. When rolling it’s better (obviously) but now I’m noticing at low rolling speeds like in parking lots, turning and using the brakes (to park), it’s getting worse. Like the steering turns super easy into the parking spot, then use a little brake to slow down and the power steering stops. So here’s my questions, is this typically what happens when the rack in these trucks goes out? There’s no leaks, no noise, no play, plenty of fluid. 75% of the time steering is great and easy. Second question, other than a modified Tundra rack, IF I have to replace this current rack, is there anything I can do or available to strengthen or beef up the factory rack at all?
  2. Nov 26, 2019 at 6:58 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    That sounds like an issue with the pump not putting out enough pressure. But it could also be a rack issue as well
  3. Nov 26, 2019 at 7:01 AM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    If the rack isn't leaking, the power steering pump is probably getting worn out
    Edit: the rack could also be leaking internally.
    ovrlndkull likes this.
  4. Nov 26, 2019 at 7:57 AM
    Armament
    Nick
    Albuquerque, NM
    Where would I see leaking? Because there’s no fluid loss that I can tell and nothing under the truck
  5. Nov 26, 2019 at 8:07 AM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    My truck does the same. It's on 305s. If I rev it up a few hundred RPM over idle it'll turn the tires just fine though, even at a dead stand still. Makes me think its a pump issue?
  6. Nov 26, 2019 at 8:13 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Ive had my rack go out with no leaking. I went through 4 tacoma racks while on 35s. Now i have a tundra rack. I can go full side to side at a dead stop.
  7. Nov 26, 2019 at 8:13 AM
    Armament
    Nick
    Albuquerque, NM
    Hm, maybe. The rack “seems” fine...
  8. Nov 26, 2019 at 8:14 AM
    Armament
    Nick
    Albuquerque, NM
    Sounds like I need to find out if I have a rack or pump issue
  9. Nov 26, 2019 at 8:16 AM
    Mademan925
    Nick
    Discovery Bay, CA
    The pump is cheaper. swap that first.
  10. Nov 26, 2019 at 9:03 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    That's how my pump was more than likely the pump. Doesn't mean you won't/aren't having rack issues also. Tacoma racks are pretty weak especially for wheeling and big tires.
    reg0928[QUOTED] likes this.
