rack n pinion bolts backing them selves out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05yota, Jan 4, 2011.
  1. Jan 4, 2011 at 9:23 AM
    05yota
    05yota [OP] Well-Known Member
    Beaufort SC
    05 Dbl Cab Long Bed
    Alpine IVA-W205 Double din TV, 10in Memphis shallow mount sub, Rockford Amp, 23in Akuza Bounce Rims!!!
    So have been haveing a weird metal on metal sound comming from the front of my truck had toyota look at it when i got an oil change they said it was the drums needed to be cleaned and get adjusted kinda weird to me but ok and the noise went away for a couple of days then it came back so i went in today and they said that the rack n pinion bolts started to work there way back out is this normal... they were the ones who did my last alignment??? the noise is gone but if they backed out once wouldnt there be more of a problem to fix then just retighting some bolts?
