Rack & Pinion issue
Discussion in 'Wheels & Tires' started by abner, Feb 6, 2014.
  1. Feb 6, 2014 at 2:41 PM
    abner
    abner [OP] Abz
    abner
    SoCal
    08 dbl cab 4x4
    Hello. I'm hoping someone can help.
    I have a 2008 Tacoma 4x4 DBL CAB Sport with a 6 inch Phase 1 Pro comp lift and 33 in tires.
    I recently had a leak in the rack and pinion so I replaced it with a Mavel aftermarket R&P. The problem is that the tie rods on the Mavel R&P are longer than the factory R&P. I went to have an alignment but the guy told me he can't align it properly because the tie rods don't have enough threads to allow proper alignment. We though of cutting the tie rods but alignment guy said if we cut it he still may not be able to align.
    I double checked that the correct part was ordered and we even ordered from 2 other manufacturers and all of the R&P's are also longer.
    We ordered for 2008 model, 4x4 dbl cab sport. I don't know what to do. Please help if you have any knowledge on this matter. Thanx.
