Rack & Pinion Power Steering Line
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gwkinvest, Aug 29, 2014.
  1. Aug 29, 2014 at 1:55 PM
    gwkinvest
    gwkinvest [OP] New Member
    Western Colorado
    2005 Tacoma 4WD
    I have a 2005 Tacoma double cab 4wd. There is a leak on the longest power steering line attached to the rack & pinion. This line can't be purchased separately from the rack & pinion through Toyota.
    I would like to purchase this line or a used rack & pinion to get the line. Unless anyone knows of someone with the metric fittings that could fabricate a solution.
    Thanks so much for your response!
  2. Aug 29, 2014 at 2:00 PM
    BamaToy1997
    Bill
    Navarre, FL
    Could you be a bit more specific on the line? perhaps include a picture? The pressure and return lines are sold separately. Unless you are referring to the crossover line.
