Rack Steering Question......
Discussion in '5 Lug' started by Racerboy221, Apr 9, 2011.
  1. Apr 9, 2011 at 12:02 PM
    Racerboy221
    Racerboy221 [OP] Well-Known Member
    Bill
    Litchfield Park, AZ
    Tacoma 2.4, Std cab/bed, 18"wheels,airshocks
    18" Wheels & Tires, Airshocks, CB Radio
    I drove through an area with some shattered Bamboo and a piece struck and punctured my steering boot on the rack. Sadly, this is now allowing power steering fluid to leak out and I am forced to continue to refill it every couple of days...as well, I cannot park in the driveway due to the staining.
    My questions are these:.....
    Can the boot be replaced easily or should the entire rack get replaced??
    Is this something I should do myself or take it to be done?
    Any assistance woud be greatly appreciated!!!
  2. Apr 10, 2011 at 3:18 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    It's leaking P/S fluid from the rack??
    If so, time for a new P/S Rack.
  3. Apr 10, 2011 at 1:32 PM
    Racerboy221
    Bill
    Litchfield Park, AZ
    Yes, its leaking from a small hole in the boot caused from a piece of wood/bamboo I hit somewhere along the road.
    I checked with a shop here and they say the book can be replaced....somewhere in the area of $110 for parts and labor. I really just wanted to do it myself (if possible) but I might still need to get an alignment when through.
    If the rack does need to be replaced, is that a fairly easy job? What does a rack cost?
  4. Apr 10, 2011 at 3:35 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    That is just a dust boot. If there is fluid inside, the rack is leaking.
  5. Apr 10, 2011 at 3:59 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Yuppers.
  6. Apr 10, 2011 at 9:14 PM
    alexmxman185
    alexmxman185 Keepin' it dirty in Texas
    Alex
    Waco, Texas
    08 toyota tacoma 2.7 4 cly 5 lug
    Black grille guard with mounted kc road lights, 31x9.5x15 AT on stock rims. My future mod list: new white front bumper, Fat Bobs 2.75 spacer lift with rear AAL, american racing Flat Black Rims, 32x11.5x15 BFG A/T, satoshi grille with road lights mounted behind it, 8000k HID for all lights, 1'' Body Lift, new window tint, blacked out headlights and taillights, custom hood scoop, weather tech floor liners, LED dash cluster replacement, Front bilstein shocks, 40 series flowmaster, paint all my badges black.
  7. Jun 20, 2011 at 11:57 AM
    s1deout
    s1deout Active Member
    PGH
    1996 Tacoma Regular LX, 2.7, 5 Speed
    Both of my dust cover boots are torn. I just ordered replacements and the guy at Advanced auto said that there should be a grease pack included.
    Anybody have a write up on replacing the boots?
    Thanks!
  8. Jun 20, 2011 at 8:55 PM
    ISUGrad05
    ISUGrad05 Public Servant Enemy #1
    Wichita, KS
    2012 4x4 5.7 Tundra DoubleCab
    No. But here you can download the factory service manual and see what all is involved:
  9. Jul 13, 2011 at 8:56 AM
    carattini
    carattini Well-Known Member
    David
    Puerto Rico
    08 base model
    the boot is not a seal for stering fluid it just for dust so the problem in not that the boot is broken their is a seal broken inside the boot and that my friend is a job for the shop and a new rack will be way grater than that.
  10. Jul 13, 2011 at 9:10 AM
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
    HAHAHA... They no comprende.
    If your rack boots are leaking fluid you have a bigger problem then leaking boots... As in the power steering rack is leaking into the boots... which means a new rack is needed.
    please someone else say in a diffrent way one more time
  11. Jul 24, 2011 at 6:15 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    what are 96-04 5 lug racks going for ? im in need of a new one.
  12. Jul 24, 2011 at 9:54 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    looked one up on kragens site cheapest is 310. id check out a mini truck salvage yard
  13. Jul 25, 2011 at 10:02 AM
    NakedTacoma
    NakedTacoma Well-Known Member
    West Covina
    Mid travel front Long travel rear
    i rplaced my rack on my 05+ mini and it was 150ish on ebay from an online wrecking yard.......... i did the install my self wasnt to hard. getting the steering straight was the hardest part
  14. Jul 25, 2011 at 4:37 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Dude at advance is trying to sell you cv joint boots. There is no grease in a steering rack boot.
