Rad/Front Body Mounts Shot
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CanyonRunner, Jul 7, 2016.
  1. Jul 7, 2016 at 11:28 AM
    CanyonRunner
    CanyonRunner [OP] 100% PENETRATION
    Pacific Northwest
    2016 TRD 4X4 DCSB
    $$$ Money Pit $$$
    If you have a squeak, bang, clank, metalic-sound, ect coming from the front, most noticeably in slow speed parking-lot/off-road maneuvering, check only the very front two body mounts by the radiator.
    Catch-up
    OEM mounts shown, you can see the wear groove on the Driver-side metal sleeve that had also cut through rubber mount making contact with frame horn.
    Groove close-up Driver-side metal sleeve
    Driver-side worn/cut completely through
    Passenger-side almost completely through, significant wear line started
    New poly mounts installed
    I think the driver-side was worse from possibly the battery/front taco lean. The lean from D/P in the front with the new poly ones is almost non existent now, noticed OEM rubber was to soft and compressing more on driver than pass. To note: I am also running no sway-bar on kings if that makes a difference on forces at hand here?
    Noise's I was experiencing are 100% gone now and am F'n happy!
  2. Jul 7, 2016 at 11:32 AM
    CanyonRunner
    Pacific Northwest
    2016 TRD 4X4 DCSB
    $$$ Money Pit $$$
  3. Jul 7, 2016 at 12:28 PM
    RM61188
    RM61188 Drives a 4Runner on a tercel budget
    Rodney
    New Orleans
    2017 T4R TRD OFF ROAD
    Now this is what ive been looking for. Thanks a lot man
  4. Jul 7, 2016 at 12:54 PM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    +1 thanks for sharing.. I have that rattle sound I can figure out where its coming from at low speed like >5mph... only one kit will do for this??
  5. Jul 8, 2016 at 3:31 PM
    RM61188
    Rodney
    New Orleans
  6. Jul 8, 2016 at 3:33 PM
    RM61188
    Rodney
    New Orleans
    Theres no way to access these things without taking a whole bunch of shit off. Am i right?
  7. Jul 8, 2016 at 4:45 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Initiative; you have it.
    Out of curiosity...
    How many miles did you have prior to the sound?
    Did you ever retorque before that?
    We're they abnormally crushed?
  8. Jul 8, 2016 at 5:31 PM
    RM61188
    Rodney
    New Orleans
    Its on and off for me. Some days I hear it. Some days I don't. My dad and I looked for the core support mounts today, found them, and realized the whole inner fender needs to be removed to access them. Fortunately today im not hearing that chirping bird call like metal on metal squeak. So i gave up on it. Canyonrunner makes it seem as easy as removing the gas cap. Or am i just an idiot and looking at the wrong bolts?
    CusterFan likes this.
  9. Jul 9, 2016 at 3:41 PM
    CanyonRunner
    Pacific Northwest
    2016 TRD 4X4 DCSB
    $$$ Money Pit $$$
    I have under 3k, I think the noise started around 1500 miles. Yes I retorqued a few times and lube, which did nothing. As you can see one was completely shot and the other was almost worn through as well, Which is why lube/tightening/loosening didn't do squat.
  10. Jul 9, 2016 at 3:43 PM
    CanyonRunner
    Pacific Northwest
    2016 TRD 4X4 DCSB
    $$$ Money Pit $$$
    Shit took 30 min for both sides, done. Didn't remove anything, remove nut on bottom, take bolt out top, there is room!
    Ozzy_Wuz_Here likes this.
  11. Jul 9, 2016 at 8:11 PM
    RM61188
    Rodney
    New Orleans
    Ok... I'm certain I'm getting to be a huge PITA right about now but i gotta ask a huge favor. Take a video of how you're looking at these bolts, like thick angle you're viewing from, to better help my apparently inept ass access them and install my $20 bushings. Actually even a few pics would work. Just make it obvious of where you're looking from. Please and thanks
    bulldog likes this.
  12. Jul 9, 2016 at 9:07 PM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    Mine started at 2800 and only lasted a few days. This time started around 4900 miles and continues weeks later at 5450 miles. I will absolutely investigate this tomorrow. I am not fixing it but would like to show dealer for reference. Is picture facing forward on passenger side or facing rearward on driver side.
  13. Jul 10, 2016 at 12:01 AM
    cheecha
    cheecha Active Member
    Guam
    I seem to be hearing this from the front passenger side when I go over bumps. Can you fellas please explain? Is it normal to hear some tuff rattling underneath. Its only a week old and its unusual for a new truck to be making rattling noises.Thanks for the help fellas, loving the 16, but this noise is bothersome.
  14. Jul 10, 2016 at 5:42 AM
    mrproduxn
    steve
    Retired DoD SE VA
    If you hear a rattle then I would stop at the dealer and see if your spare tire is anchored tight against frame. Possible running board loose. I think the main problem we have involves squeaks.
  15. Jul 10, 2016 at 4:39 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
  16. Jul 10, 2016 at 7:26 PM
    mrproduxn
    steve
    Retired DoD SE VA
    Just realized pic is prob with no air dam. Gotta drop mine to get same view. Seems like the right location of noise.
  17. Jul 13, 2016 at 2:53 PM
    mrproduxn
    steve
    Retired DoD SE VA
    Dealer did say they are aware of an upcoming flash for the transmission. Could be 2 weeks. Could be 2 months.
  18. Jul 14, 2016 at 3:17 PM
    mrproduxn
    steve
    Retired DoD SE VA
    Update. Dealer said Toyota will replace my passenger side body mount bushing. They said Toyota has seen one case of a misaligned radiator mount support failure from manufacturing. Really. Just one. Anyway I told the dealer to eliminate the risk and replace both. He really thought that was funny. No way. Not gonna happen. Thank Mr Toyota for saving the company another $10 part. So how long should the driver side last. It carries a little more weight than the passenger side.
  19. Jul 15, 2016 at 6:17 PM
    RM61188
    Rodney
    New Orleans
    image.jpg Finally got it done. Wasn't fun removing the grill and bumper and getting the stock garbage ones out wasn't very easy. But the noise is gone and my ever escaping peace of mind is back for a little while longer
  20. Jul 15, 2016 at 6:31 PM
    splitbolt
    NW Arkansas
    Can you say if it's part quality or improper installation that caused them to fail?
    I've heard it mentioned, some have been installed sideways(whatever that means) or have inconsistent bushing squash between mounts.
    Jinx3Mt likes this.
