Radar Control
Discussion in '3rd Gen. Tacomas (2016-2023)' started by willee51, Nov 23, 2022.
  1. Nov 23, 2022 at 5:31 AM
    willee51
    willee51 [OP] willee51
    Bill
    Forest, VA
    2022 SR5 DCSB AT 4X4, 6-cyl MGM
    The past few mornings, in the high 20's, my radar control has been "Radar not available".
    There is a yellow triangle icon, with an explanation mark in the center, and my radar icon is yellow, with a message "Radar Unavailable" (has happened off and on 4-5 times).
    However, after about 15 minutes, if i turn the truck off and back on, all is normal.
    This is a off/on problem which i'm sure the Stealership cannot remedy
  2. Nov 23, 2022 at 5:34 AM
    jjglass535
    jjglass535 Well-Known Member
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    Maybe dirt or ice on the grill sensor
    Chew likes this.
  3. Nov 23, 2022 at 5:36 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Let's start with the basic questions.
    So you have an aftermarket grille or is it original?
    Aftermarket suspension or big tires?
    Is the sensor shield clean and free of ice, both front and back?
    Is it snowing?
    Chew likes this.
  4. Nov 23, 2022 at 5:39 AM
    willee51
    Bill
    Forest, VA
    Stock grill
    Stock suspension and tires
    No snow
    Have cleaned sensor shield with window cleaner multiple times
    Rock Lobster[QUOTED] likes this.
  5. Nov 23, 2022 at 5:45 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Two more last ditch questions:
    is the top of the windshield (camera) also clear?
    Did you check the wire harness that runs under the hood to make sure it didn't get knocked loose? There are two plugs along that wire: one on the back of the sensor and one near the hood latch.
    I'd take it into the dealer. They should have a fancy reader that pulls safety codes. If nothing else, an intermittent "unavailable" error instead of the usual "clean sensor" error points to either a bad calibration or a loose wire. They should recalibrate under warranty, even for an intermittent error.
  6. Nov 23, 2022 at 6:07 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    The one time it happened to me it was in a torrential thunderstorm here in south Florida. I got a radar unavailable and clean sensor. After about a minute of driving it came back and never happened again. I assumed it was the amount of rain or some ick that got kicked up from the car in front of me and fell off while driving.
    @Rock Lobster is correct. The dealer should just check for codes and do a recalibration for you, but you know how they love to use the "we can't replicate the problem" excuse to get out of doing warranty work. Hopefully it left a code recorded somewhere.
  7. Nov 23, 2022 at 6:17 AM
    Tritiger
    Tritiger Well-Known Member
    Zach
    Kansas City
    2022 TRD Sport DCLB
    20" 4Runner Nightshade Wheels, console safe
    Does the constant speed feature still work when this happens?
  8. Nov 23, 2022 at 6:20 AM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    Something is wrong with your radar system.
    I drive in heavy snow and slop and rarely ever get that warning.
    When I do, I typically find 1/4" or more of slush on the surface of the grill...
    If your window is clean and your grill is clean, there should be no warnings at all.
    Take a video of it happening so that you can show the dealership.
    willee51[OP] likes this.
  9. Nov 23, 2022 at 6:27 AM
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    Am I wrong or do I vaguely recall a TSB related to water getting in the radar sensor and causing issues so they replace it and seal it or something?
  10. Nov 23, 2022 at 6:32 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Old TSB, the dealer did that to mine on a maintenance visit in 2019.
    And the official fix was taking a piece of sticky foam weatherstrip and covering the top of the sensor, like a ghetto rain cover. Mine was still working so they didn't replace it.
