radar detector ?
Discussion in 'Product Reviews' started by jut619, Apr 4, 2012.
  1. Apr 5, 2012 at 10:34 AM
    Whitster
    Whitster Well-Known Member
    Whit
    Golden, CO
    '09 AC w/SR5 & TRD, 6' bed
    I'll bet that hooker is really impressed with your 3 minute job...
    :p
  2. Apr 5, 2012 at 10:39 AM
    Whitster
    Whit
    Golden, CO
    Yeah if you can put up with all the Jesus Freaks and BS. Get 5 miles away from an interstate and the CB us useless unless you like to hear when Billy Bob gets called in for dinner.
    If you wanna hear some good CB chat listen to the hookers solicit the truck drivers around Elko, they really know what they're doing...even on the radio.
  3. Apr 6, 2012 at 8:48 PM
    dza1284
    dza1284 Well-Known Member
    CA
    08 OR Short Bed Dbl Cab
    Bilstein 5100, 2" AAL, Grille, BHLM, Footwell LED, Dash LED, Aero exhaust
    That is funny!
  4. Apr 13, 2012 at 9:17 AM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    I have an escort and the only time it helps is on long stretches of highway. In town it doesn't really help. And just because I have it doesn't mean I speed all the time. It actually made me realize that 90% of the time cops aren't radar-ing. I still laugh when a cop goes by and all the cars slam on their brakes when he isn't even looking for speeders.
  5. Apr 13, 2012 at 9:25 AM
    Cowboyz
    Cowboyz Membor
    Luke
    Southern Utah/Las Vegas
    07 DC LB TRD Sport
    6in Pro Comp stage 2 lift, 2.75in ProComp Coilovers, Rear MX6 adjustable shocks, 35in Nittro Trail Grapplers, 17 in XD Spys, URD intake, URD MAF Calibrator, Flowmaster 40 Series, AMP Power steps, debadged, blacked out tail lights, Blacked out headlights w/ Mini H1 Retros and halos, JVC KW-AVX840 7" Double-Din, Viper 5704 2way alarm/remote start, LEDs in Dome, Maps, and license plate lights, short black antenna, 5% Tint, removed sway bar
    Not when you buy a decent detector. I spent 225 on mine and it has paid for itself 10x over again. Cops in Utah/Vegas have their detectors on ALL THE TIME. My detector starts going off like .5-1 mile in advance. I dont speed all the time but when it goes off, it just reminds you to check your speed and make sure your not speeding. Def worth the investment IMO. Just dont buy a cheap one cuz they wont do you any good
  6. Apr 13, 2012 at 9:41 AM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    I like the remote mounted ones the best, very small display mounted anywhere in the cab that suits you (and out of sight from thieves) and the antenna mounted behind the grill. You have to use your head a little, just keep some one in front by a moderate distance. If the officer is really playing, and your alone and speeding, you bought yourself a ticket. Here's what I use, it's a good unit, the Valentines and Escorts are considered the best, but are pretty costly.
    http://www.radarbusters.com/radar-d...tectors/whistlerpro3450radarlaserdetector.cfm
  7. Apr 13, 2012 at 9:50 AM
    NoSoup4You
    NoSoup4You Well-Known Member
    David
    Palos Verdes
    2008 DCSB DMZ LT 4x4
    Camburg | King | Glassworks | DMZ | Nitro | Banks | Pelfreybilt | Brute Force Fab | Bay Area Metal Fab | Baja Designs | Rigid Industries | STL
    ^^definitely not the best idea.
    Radar detectors should be mounted as high as possible to get the best viewing position on the road.
    Mounted high in the windshield is where they are designed to go for a reason. Behind a grille will just add interference and reduce your detection distance significantly.
    Also, what happens when a cop sneaks up from behind? Then you have an entire car blocking your antenna from the radar.
    Really, remote displays are designed to get the display in a safe comfortable position - not to relocate the detector to a hidden, less useful location (unless you have multiple sensors and all that - which is way more than a $250 detector)
  8. Apr 13, 2012 at 9:57 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I have an Escort 9500i. Id stick with Escort or Valentine. Good tool if you use it with common sense. If you have it to blatantly speed then you'll get nailed eventually. To just say dont speed is also dumb just as a blanket statement. What does one consider speeding? Anything over the speed limit or over enough to get pulled over? You could be doing 60 in a 55. Technically thats over but youre likely not getting pulled over nor are you endangering anyone. Hell the one highway here the troopers dont generally bother you unless youre 15 or more over. And im usually only 10 over. Sure if youre going 95 all the time you could make the argument to just slow down.
  9. Apr 13, 2012 at 9:59 AM
    t4daddy
    North Alabama
    Depends on what you read. Some say it's a better picture of the road because its the leading part of the vechicle and because of reflected waves of the hood, (if mounted higher) and plastic (grill) doesn't restrict as well. I've read both sides of the argument.
  10. Apr 13, 2012 at 10:07 AM
    NoSoup4You
    David
    Palos Verdes
    A plastic grill would definitely do less damage than metallic, so for those that aren't Satoshi or similar should be all good :cool:
    I never heard about the hood helping radar before, but I have read that white hoods especially are terrible when you have windshield mounted detectors - all kinds of bad reflections I guess
    EDIT: just noticed you have a white Taco - ^^that wasn't a direct hit. I used to run radar in my white Ford Escort
  11. Apr 13, 2012 at 10:15 AM
    t4daddy
    North Alabama
    I was talking about the hood "bouncing" signals up and away from windshield mounted units, hurting reception. Here is a little light reading, read the fourth paragraph closely.
    http://www.radardetectortechnologies.com/remote-mounted-radar-detectors.htm
  12. Apr 13, 2012 at 10:59 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    My vote is for the Escort. I have the passport X50 and I've been very impressed with the performance. Only other one I would consider is the V1.
  13. May 20, 2012 at 6:29 PM
    Liutas
    Liutas Member
    SoFlo
    Long road trips? Just doing 10 over, which isn't even dangerous (in fact, some places that's slower than traffic is moving) over a ten hour drive will get you 100 miles further down the road. 15 Over will get you 150 miles further along. That's pretty significant when you're travelling 1,000 miles or so.
  14. May 21, 2012 at 2:50 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    passport 9500ix with blendmount
  15. May 22, 2012 at 1:45 PM
    #35
    mogace
    mogace Well-Known Member
    Southaven MS
    reading this and seeing lots of haters and lots of praisers. I have an escort 8500, had it for years, and highly recommend it as well as 9500 and the V1. Valentine is best by far, speaking from experience in selling these as well as comparing one I borrowed from a friend to my 8500. $300 is about average for these if you buy them used. One thing, if you buy them used, call the manufactuer and see if you can have it updated.
