Radar vs Reality
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Willy Lump Lump, Nov 2, 2024.
  1. Nov 3, 2024 at 5:33 AM
    Sig Taco
    Sig Taco Well-Known Member
    2021 Taco DCSB
    Icon Rebounds 17x8.5 Toyo 35/12.5/17 JBA UCA, Bilstein 6112/5160, KDMax
    I'm on Toyos 35/12.5/17
    When my speedometer indicates 70mph, Google maps GPS shows 77mph. Speedometer 80, GPS 88.
    I've done some 84mi trips per Google maps. My odometer would register 74.x miles. So my odometer is understated by 12%.
  2. Nov 3, 2024 at 6:06 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    Who knew that Toyota would be THAT nanny-ish. Up to now, I always thought that the GPS speed, shown, was “off”. (How could Toyota be wrong?) Thank goodness I’m not inclined to hang in the fast lane and drive the speed shown in the cluster.
  3. Nov 3, 2024 at 6:18 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    OP, if you’re that concerned about the speed being accurate (not a dig at you - I’m one of those people) you can always get a speedometer calibrator.
    I have the hypertech speedometer calibrator because I run 33” tires and my speedo is very accurate.
    Willy Lump Lump[OP] likes this.
  4. Nov 3, 2024 at 6:39 AM
    Willy Lump Lump
    Willy Lump Lump [OP] Well-Known Member
    21’ dcsbmt
    This and that
    Honestly I was just wondering where everyone was. Meaning how many trucks are high, low, dead nuts on.
    Road_Warrior[QUOTED] likes this.
  5. Nov 3, 2024 at 6:54 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Well then to answer that question for my truck…my Speedo was a couple MPH off (low) with the OEM tires (245’s).
    When I upgraded to 265/75/16 tires, the Speedo was 100% accurate. Now with my 33’s it would be a couple MPHs off in the other direction if I didn’t have the speedo calibrator.
    The amount that the Speedo is incorrect also varies by speed. It will be more inaccurate at higher speeds, if it’s not accurate.
  6. Nov 3, 2024 at 7:02 AM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    You guys worry about speed limits?
    The rules are made up guys, that's all. Most are unnecessary.
  7. Nov 3, 2024 at 10:22 AM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    Twenty five mph is slow enough that variances between the street radar unit and your speedometer may not show. Get to highway speeds and you'll start to notice a discrepancy. I know my motorcycle reads about 1.5 mph fast from actual GPS at normal speeds but past triple digits the variance increases. Phone "GPS" don't actually use satellites; but calculates location via cell towers so it's not as accurate as a true satellite based GPS.
    Like any instrument they're as accurate as how they're set. The radars in our patrol cars rarely get out of calibration despite living in a bumpy environment that's exposed to temperature variances. If so they need to go back to the factory as they don't get "calibrated" by the end user. However the calibration is easily confirmed by the officer regularly with tools.
    So in a nutshell, factory speedometers aren't as accurate as radar or GPS but close enough.
  8. Nov 3, 2024 at 3:59 PM
    Willy Lump Lump
    21’ dcsbmt
    This and that
    Well gps for civilians is def not as accurate as it could be.
  9. Nov 3, 2024 at 6:00 PM
    Willy Lump Lump
    21’ dcsbmt
    This and that
    Did this, updated my phone and all apps. Still doesn’t display a speedo. Now I just feel old.
    TnShooter[QUOTED] likes this.
  10. Nov 3, 2024 at 6:14 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I have an Apple.
    I just pulled those directions off of Google.
    Pretty sure Waze does speed too.
    I'll have to take a look next time I drive.
  11. Nov 3, 2024 at 6:27 PM
    TnShooter
    Deogee
    STOCK
    Just went down the road and checked.
    Waze does show real time speed.
  12. Nov 3, 2024 at 6:44 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    My truck's indicated speed was dead on from the factory, unlike some others here on this forum. Increased the tire size and had to interpret, then put in a speedometer calculator correction and was pleasantly surprised as to the returned accuracy. Had to fiddle with the settings of the Hypertech quite a bit to my satisfaction. Should have done it years ago, but at that time the cruise control display was not corrected. If you do go to a Hypertech unit leave the programming cable attached and available below the dash for future programming.
  13. Nov 3, 2024 at 6:48 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Are you sure it was the speed that was correct from factory and not the odometer? From the factory, in every truck I’ve ever been around, the speed reads fast by a few mph at highway speed, but the odometer is spot on so as to not speed up warranty.
    Tested this in numerous trucks and all are identical in my testing.
  14. Nov 3, 2024 at 6:48 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    I use a 10-year-old portable Garmin GPS. At least I can take it with me if I god-forbid must abandon the truck or if I rent a vehicle. Before changing shoes to Falken AT4 analog speedometer match it enough I did not notice. Now the analog speed is 2 MPH below the GPS.
  15. Nov 3, 2024 at 7:40 PM
    #35
    Toycoma2021
    Positive as to the speedometer, collaborated by two GPSs; I pay no attention to the odometer. I took notice because it was accurate, unlike all previous vehicles I have had.
  16. Nov 6, 2024 at 9:17 PM
    #36
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Pics of the Trans Am, please.
    boston23 and Willy Lump Lump[OP] like this.
  17. Nov 7, 2024 at 3:32 AM
    #37
    BillyE
    BillyE Well-Known Member
    Radar does not show true speed, but rather speed relative to the radar unit. Look up “cosine effect”. A radar mounted off the side of the road is likely to read low and will be less accurate as you approach.
  18. Nov 7, 2024 at 6:19 AM
    #38
    Willy Lump Lump
    21’ dcsbmt
    This and that
    If this involves algebra that’s a hard pass.
  19. Nov 7, 2024 at 6:27 AM
    #39
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    My speedo is MORE accurate with the 265/70R17s than it was with the stock tires. At 70 mph it used to read 2 mph high. Now it reads 1 mph low.
    Willy Lump Lump[OP] and BillyE like this.
  20. Nov 7, 2024 at 11:38 AM
    #40
    TnShooter
    Deogee
    STOCK
    Sold it. It was fun, until it wasn't.
    It's never a good idea to restore a Daily Driver.
    All my free time and weekend went into that car for almost 2 years.
    I got burnt out and sold it.
    There may be some pictures of it floating around somewhere.
    My parents might have them. I took on this project in High School.
    Sold it my senior year, and bought my first Tacoma. A 1996 Regular cab, 2.7 4X4.
