raddle noise driving me CRAZY
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tuctaco, Aug 15, 2014.
  1. Aug 15, 2014 at 9:38 AM
    Tuctaco
    Tuctaco [OP] Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
    I have this raddle that is driving me crazy. It sounds like one of the heat shields, but I've checked and they are tight. It started after I changed my plugs and did an LOF. I made sure that everything I took off is tight.
    I did a search, but found nothing. Any idea's?..Thanks
  2. Aug 15, 2014 at 11:16 AM
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
    You gotta say under what conditions you hear it, and where it sounds like it's coming from, as well as how loud.
  3. Aug 15, 2014 at 3:59 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Not Saying this is it, but my last GMC did that really only at an idle or low rpms. I traced it to the Cat - loose baffle plate. IF it is it should be covered by powertrain/emission warranty... Hope it's not that.
    Did you move any sheet metal used for heat shielding on the engine ??
