Radiant red wax
Discussion in '2nd Gen. Tacomas (2005-2015)' started by michael11993, Sep 3, 2011.
  1. Sep 3, 2011 at 8:57 PM
    michael11993
    michael11993 [OP] Well-Known Member
    2006 PreRunner
    Tint 12 in kicker Amp Viper Alarm sytem Dual floater exhaust K&N air filter X-D Series Black Rims
    I have a radiant red taco and im planning on waxing it tomorrow. Whats the best wax for the color?
  2. Sep 3, 2011 at 9:09 PM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    Any wax will work as long as its quality wax. Doesn't matter the color of the truck.
  3. Sep 4, 2011 at 3:44 AM
    808TRDTaco10
    808TRDTaco10 Black Sand Mirror
    Justin
    Big Island, Hawaii
    10 Access Cab TRD OR 5AT 4x4; 08 Regular Cab 5MT 4x4
    TRD Off Road 265/75/16 Goodyear Wrangler Duratrac Load Range C | Toytec Ultimate Lift with Emu Dakar Leaf Packs | 3* Axle Shims, CB Drop, Sway Bar Relocates | AVS Vent Visors, AVS Bugshield | Scangauge II | Wet Okole Seat Covers | Weather Tech Floor Liners | Pop n Lock | OEM Bed Mat | Truxedo Lo Pro QT Tonneau Cover | TRD Cat Back Exhaust | Aftermarket Alarm System | Pro Coat "Electronic Rustproofing"
    Try Meguiar's NXT 2.0 wax. I think it's some pretty good stuff and it really makes water bead if you apply enough coats. What specifically are you looking for in the wax though...protection of the paint, shine, etc.? If you are looking for a really nice deep shine, then I'd recommend a carnauba type wax.
  4. Sep 4, 2011 at 3:47 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    zymol makes a wax especially for red colored vehicles, and zymol is top of the line wax.... i'll add in a link with the edit.
    EDIT:
    http://www.autoanything.com/car-care/69A3065A0A0.aspx
    It's expensive, but this tub will last you for the better part of a year, if not more. I use creame on my trucks/cars, and it's great- A friend of mine has a red 05 mustang GT, and this wax gives the best depth/clarity/paint preservation i've seen.
  5. Sep 4, 2011 at 4:05 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
  6. Sep 4, 2011 at 4:53 AM
    schleygo
    schleygo Well-Known Member
    Daniel
    Ft Worth TX
    07 Dbl Cab Radiant Red
    Bilsten 5100s, Eibach Coils, 2" toytec AAL, LR UCAs, SC5 Matt Bronze
    I got a rad red also.
    Don't get worried when you wax your front bumper and fender flares when your application pad turns red. Toyota did not clear coat them, so paint will come off when you wax those parts.
  7. Sep 4, 2011 at 7:40 AM
    SilverTacoEater
    SilverTacoEater Well-Known Member
    Pasadena, MD
    11 Tacoma SR5 4X4
    Stock
    I really like the Meguires NXT wax. Its fairly easy to find most anywhere, isn't expensive, seems to give a nice shine and good protection, and seems to last a while between waxing. My only problem with it is it seems to take a little more elbow grease to remove the film left behind. Usually when i'm done I take it out into the sun and look over it carefully and wipe it down one more time with the microfiber towel. The caranuba wax is also very good. I just like the NXT a little better because it seems to stay on longer and i think it gives a richer shine.:notsure:
    If you're looking to really protect your paint and get a really rich shine you should do a full detail. I usually clay bar the entire truck. This removes most, if not all, contaminants in the paint and brings it down to the clear coat. :D
    I then use Meguires #21 Synthetic Sealer. This seals the paint and protects it.
    Then i usually go to the #7 Show car glaze. This really brings out the color and a deep shine. That show car glaze really makes red cars pop.
    Then the last thing i use is the wax. I usually do about 2 coats.
    Granted I do all my stuff by hand because i dont trust myself with a rotary buffer so it takes me like 6-8 hours and a whole lotta beer to do my whole truck. :eek:
    Its well worth it though. I attached some pics so you can see the final results. the black car is my civic si i had before the Taco and the red car is my gf's accord. The pics of the accord arent that good because it was cloudy out so you can't really get a good idea of how good it actually looked.
  8. Sep 4, 2011 at 8:24 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Megs #21 and #7 is a great 1-2 punch.
  9. Sep 4, 2011 at 9:04 AM
    vtdog
    vtdog Well-Known Member
    Don't use "wax" at all-you are just wasting your time as wax jobs do not last. I use "Nufinish" which is some type of polymer coating. It applies like wax, but last a very long time. In fact, I only have to do it 2x a year. Yes, it does not give you the "deep" shine you can get with some car waxes, but I don't coat the paint for the shine, but for the protection. The only thing to be aware of when using nufinish is that after you wipe it off it takes about 20 min for the hard shine to show up. The application I did last April is still beading up today. I will do another in about a month to get me through the winter.
    That's my 2c on this
  10. Sep 4, 2011 at 11:49 AM
    michael11993
    2006 PreRunner
    thanks guys. I just got Carnu-B wax. Is that good wax? Any feed back is appreciated!
  11. Sep 4, 2011 at 11:57 AM
    SilverTacoEater
    Pasadena, MD
    11 Tacoma SR5 4X4
    Stock
    Ive used caranuba wax several times with great results. what brand?
  12. Sep 4, 2011 at 12:01 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    You put glaze on top of a sealant? you're doing it wrong...
    ...And for red, I would go with Dodo Juice Hard Candy. Remember, no matter how good a wax is, it will look like shit if you don't prep the surface correctly.
  13. Sep 4, 2011 at 12:07 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    "Carnu B" is the brand. I've never used it myself or know anyone who has, but carnauba wax's give a better shine then sealants, but don't last as long.
  14. Sep 4, 2011 at 12:13 PM
    michael11993
    2006 PreRunner
    So Carnu-B is great for deep shine? What about protection from the weather? What do you mean my prepping it?
  15. Sep 4, 2011 at 12:22 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    It should be, if it really has carnauba in it. Protection is carnauba's down side, they only last 2-3 months. Sealant's will last up to 6+ months, but they don't give the same shine as carnauba wax's.
    By prepping I mean: clay, polish, glaze (optional), then wax/sealant. Depending on how bad your paint is, you can even use a rubbing compound before polishing.
    There's a lot more to it than just slapping on a coat of wax.
  16. Sep 4, 2011 at 12:33 PM
    michael11993
    2006 PreRunner
    Im gonna clay bar my taco today. The paint is still very good. I wax it with meguirs at least once a month. So should I clay bar it then apply the carnu-b wax?
  17. Sep 4, 2011 at 12:38 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    I would still do a polish to get rid of any swirl marks and faint scratches. A good polish is really what makes the wax shine!
  18. Sep 4, 2011 at 12:55 PM
    michael11993
    2006 PreRunner
    what type of polish?
  19. Sep 4, 2011 at 1:00 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's, Pioner AVH-2300NEX w/backup camera, SCT X4 Tuner.
  20. Sep 4, 2011 at 1:15 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Pacific Northwest
    2018 OR DCSB 4x4
    NuFinish is a polish. If you know what you are doing, it is OK to use (only once in a while). Polish is abrasive and wears down the clear coat over time. It gets over-used all of the time by people that don't quite understand how it works. For the average person, you are best off sticking with a high quality wax. Lately I have been using Meguiars Ultimate. For the price, it is the best I have found. It is a big step up from the NXT I was previously using.
