Radiator air deflectors?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacohumper13, Jan 12, 2019.
  1. Jan 12, 2019 at 12:22 PM
    Tacohumper13
    Tacohumper13 [OP] IG @_.mfa_
    Menifee
    2017 TRD Off-road DCSB 4x4
    6112/5160s w/ camburg UCAs 265/70/17 wildpeaks JP8 conversion kit
    just added the hidden bumper light bar. Install calls for removal of the radiator air deflectors.
    What do they do? Pros and cons to removing them?
  2. Jan 12, 2019 at 12:25 PM
    tcjacado
    tcjacado Well-Known Member
    Think it means the pieces on the sides that funnel the wind into the radiator.
  3. Jan 12, 2019 at 12:28 PM
    Tacohumper13
    Menifee
    Pretty basic I guess? I do see how a lot more holes are open now on the side of the radiator into engine bay. Guessing more dust at what not?
  4. Jan 12, 2019 at 12:30 PM
    tcjacado
    If you are on a trail behind another truck..... especially in the desert the dust is getting everywhere regardless.
    I suppose it just has more to do with cooling the radiator.
  5. Jan 12, 2019 at 10:24 PM
    jdmstuff
    jdmstuff Well-Known Member
    Derrick
    Torrance, CA and Las Vegas, NV
    '18 TRD OR DCSB AT, '08 TRD Sport DCSB AT, '03 TRD 3.4l 4x4 MT Supercharged
    It's there to concentrate the air directly into the radiator core. Without it, the air coming in just blows around that large opening. Think "path of least resistance." You can easily just cut the bottom of the deflectors off and they'll still hang on with one push rivet. I cut mine down to clear the brackets by simply scoring the panel with a razor knife and bending it until it snapped clean. I did run without them for a couple of months when I first installed the brackets, but got tired of looking at them sitting in my garage, so I put them back on instead of throwing them out.
