Radiator cap leaking AGAIN!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Janster, Mar 14, 2012.
  1. Mar 14, 2012 at 4:11 AM
    Janster
    Janster [OP] Old & Forgetful
    Jandy
    Lancaster, PA
    My truck is 5 years old and the original radiator cap was replaced under warranty because it was leaking and I was loosing fluid. Now.....a 2-3 years later, the replacement cap is leaking again.
    What the...??
    I really don't want to buy another Toyota cap again and have to replace it in another 2 years.
    The stock cap is 13 psi (per another thread).
    Any suggestions for a good reliable cap? Or just go and buy whatever the local auto store has in stock? I'm game for anything....
    Thanks!!
  2. Mar 14, 2012 at 5:11 AM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) I am sorry that you are having problems with your radiator. I do not know how mechanically able you are, but here is an option. Most autozone and advance auto parts stores have loner tools. One of those tools is a radiator pressure tester, and some come with a adapter to check the radiator cap also.
    Since your cap is failing at a early date, you can do this right now. Remove the cap when the motor is cold and look at the bottom of the cap. There should be a rubber gasket on the bottom of the cap. Look for tears in the rubber and move the piece around to see if it stiff. Push on the spring and see if it moves without a lot of force. You may want to look around the filler neck of the radiator to see if it looks cracked or broken. If all is good then the radiator tester will help to see if you have any cracks or broken areas on the radiator.
    If your system tests good and you can find no problems with your old cap, then you will need a replacement cap. The best aftermarket cap is a Stant radiator cap. You can get them at a Advance or at a Napa autopart store.
    I do not know how old your antifreeze is and what brand it is. I can only relate a problem I had with a GM radiator that was leaking and it had the factory antifreeze in it. GM antifreeze is an organic base to it and if the radiator would be low on fluid, the resulting air inside the radiator would dry out the organic radiator fluid and it would form a brown muck that would form around the neck of the radiator and around the cap. I do not know if the toyota fluid would do the same, but if you see some mucky substance around the cap when you open the cold radiator, it could be making the cap to vent fluid out. If the cap is mucky, you could clean it under water and wash the area of the radiator that is mucky also and replace the cap to see if it will malfunction again. GOOD LUCK.
  3. Mar 14, 2012 at 5:29 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Check your filler neck's sealing area for nicks, cuts and burrs. Theyy can make your cap fail.
  4. Mar 14, 2012 at 6:25 AM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    ^^ This.
    My old Civic developed leaks around the filler tube and it took me a few radiator caps to finally realize that was the problem. Take your cap over to your local parts store and test it unless you live close enough that the coolant system won't pressurize and then you can try testing the fill tube.
    I don't have too much experience with aftermarket radiator caps and I decided to replace mine with the 16.5 PSI TRD cap after I got my S/C. (Wish I could remember where I put the original one)
  5. Mar 14, 2012 at 7:59 AM
    Janster
    Jandy
    Lancaster, PA
    Thanks Gang. The truck only has 45k miles on it. So I'm not worried about the system needing checked. I will check the filler neck more closely this time - as I remember checking it the last time - probably not close enough.
    Stant is a good name - I hope my auto store has that brand.
    Thanks!
  6. Mar 17, 2012 at 6:21 AM
    Janster
    Jandy
    Lancaster, PA
    Replaced the cap today. The STANT OE replacement cap is 16psi.
    Filler neck is fine...although, what the hell...plastic??
    Majority of the 'debris' left from the leaking is at the cap, but there might be signs of leakage along the top where the plastic meets the metal. God forbid....
  7. Mar 17, 2012 at 6:41 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Do not forget age of the vehicle- your at 4+ yrs, even if its a new truck things can and do go wrong...:rolleyes:
  8. Mar 17, 2012 at 7:20 AM
    Janster
    Jandy
    Lancaster, PA
    I thought I bought a Toyota. Whatever happened to the quality of the past?
  9. Mar 17, 2012 at 7:29 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    I know sucks to hear stories on these forums of Toyota quality, but remember as a whole we are a small group of Toyota owners which can magnify things at times :cool:
  10. Mar 18, 2012 at 5:26 AM
    Janster
    Jandy
    Lancaster, PA
    I owned a 96 tacoma for 5 years..... So, you could say I'm unfairly judging this 07 againest my 96. Quality just isn't the same anymore.
    I Love my truck!! And plan to keep it for another 5 years...!!
