Radiator capacity for 05 4.0L auto trans?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Back40, Mar 23, 2014.
  1. Mar 23, 2014 at 1:37 PM
    Back40
    Back40 [OP] Well-Known Member
    SC
    2005 4x4 Dbl Cab
    Anyone know the radiator capacity for the 05 4.0L auto trans 4x4? I only got about 1 gallon of coolant after draining the radiotor. The manual states total coolant capacity is 10.3 qts so I was expecting more our of the radiator. Thanks!
  2. Mar 23, 2014 at 2:05 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Are you talking engine coolant or Tranny cooler...??
  3. Mar 23, 2014 at 2:37 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    You will need to drain the heads also.
    A quick search will show you where to look.
    I would defiantly use Toyota coolant instead of the "fits all" coolant available everywhere
  4. Mar 23, 2014 at 3:04 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    With both block drains, the rad drain, and the overflow bottle, mine took a splash less than 8 qts.
