radiator coolant change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gen2tacocat, Jun 5, 2019.
  1. Jun 5, 2019 at 9:21 AM
    Gen2tacocat
    Gen2tacocat [OP] Member
    arizona
    2013 spruce mica trd off road
    if I flush coolant from radiator do I need to bleed air from the engine block after replacing coolant or will air bleed out from radiator alone ??I will be using a funnel kit.
  2. Jun 5, 2019 at 11:12 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I drained the coolant from the block drains (and the radiator drain) but I didn't specifically bleed air from the block drains. I just squeezed the upper/lower rad hoses until the bubbles stopped and the radiator was full. Been about 20,000 miles and no issues. I also used a funnel kit which made bleeding the air out super easy.
    BassAckwards and Gen2tacocat[OP] like this.
  3. Jun 5, 2019 at 11:17 AM
    Gen2tacocat
    arizona
    is it necessary to drain from both radiator and block ?
  4. Jun 5, 2019 at 11:20 AM
    TheDevilYouLove
    Marylandistan
    Def drain from the passenger side block and radiator, only little comes out of the driver side block and it's a pain to get to so I'd be OK skipping that one. For the two block drains, you need some clear tubing to avoid making a mess, I think 5/16" inside diameter. I had to let my block drains soak for a few days in PB blaster, they were fairly tight and I did NOT want to break them by applying too much force.
  5. Jun 5, 2019 at 11:23 AM
    Gen2tacocat
    arizona
    thanks you for the info. hope your having an excellent day.
    TheDevilYouLove likes this.
  6. Jun 5, 2019 at 11:30 AM
    TheDevilYouLove
    Marylandistan
    In case you haven't seen it, attached is the Toyota Service Manual page for coolant change. The pic of the block drains is misleading, it makes it look like one is up in the valve cover but that's looking through the engine to the lower passenger side.
    Gen2tacocat[OP] likes this.
