radiator coolant
Discussion in 'Technical Chat' started by dustinclm, Feb 27, 2011.
  1. Feb 27, 2011 at 6:32 AM
    dustinclm
    dustinclm [OP] Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    i was planning on draining/changing the radiator fluid today and was wondering if i had to use the red coolant from toyota or can i pick up any kind from autozone? since it is sunday toyota is closed but i wanted to get it done today...i live in Louisiana so freezing isnt a big issue so unless the toyota brand has something others wont i should be able to use any kind...?
  2. Feb 28, 2011 at 7:27 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    A bit late, but if you are draining the radiator and the block, or draining the rad and flushing, or something that gets the majority of the old coolant out, then you should be able to replace it with any of the major off-the-shelf coolants. The problems that some see, or hear about, are usually to do with mixing different kinds of coolants in the system.
  3. Feb 28, 2011 at 7:37 AM
    MyYota05
    MyYota05 Well-Known Member
    Muskogee, Oklahoma
    2005 Toyota Prerunner w/ TRD Offroad Pkg.
    3'' Lift Kit, Bed Rug Liner, Black Rims
    There is nothing special about the Toyota brand engine coolant, I recommend you going to Autozone and just buy some coolant to replace what you drained, they have some coolant called Peak there that says that you can mix it with any color.
  4. Feb 28, 2011 at 8:08 AM
    dustinclm
    Thibodaux, La
    After research Toyota recommends any coolant with ethylene glycol in it. thanks though.
  5. Mar 1, 2011 at 1:56 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    The red stuff is supposed to be extra life and corrosion inhibiting.. think you can still buy the green stuff. Radiators used to last a lot less time on that than they do now.
  6. Mar 1, 2011 at 6:43 AM
    4x4Runner
    4x4Runner Now with more Oi Vey! Moderator
    Drunken Sailor
    Somewhere between Maine and Florida
    2017 4Runner Smashed Ass Edition
    KDSS
